Author Topic: 69 12 bolt Eaton Rear Axle Assemblies  (Read 3856 times)
« on: January 05, 2009, 06:19:28 AM »
How complete were the Eaton 12 bolt rears when they arrived at Norwood?
Were they Drum to Drum assemblies minus the brake tubing and springs?
Re: 69 12 bolt Eaton Rear Axle Assemblies
« Reply #1 on: January 05, 2009, 09:21:32 PM »
Yes, that's correct - the brake pipes, block, flex hose, springs, parking brake cable brackets and lube were added at Norwood; the parking brake cables were part of the axle assembly as received.
