Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
General Discussion
302 small block fire order
« previous
next »
Print
Pages: [
1
Author
Topic: 302 small block fire order (Read 7916 times)
samanatoo
Member
69 Z28 Hugger Orange/Orange Houndstooth
on:
January 03, 2009, 11:58:30 PM »
Does the 1969 302DZ motor have the same fire order as other 350 and small blocks??
Tweet
Logged
Steve Shauger
Hero Member
Re: 302 small block fire order
Reply #1 on:
January 04, 2009, 12:10:36 AM »
Yes the firing order is the same as all small blocks 18436572
Logged
Steve Shauger
Vintage Certification™ Program, Providing Recognition And Status To Unrestored Vehicles. The Supercar Registry-www.yenko.net-
RAfbody
Member
Reply #2 on:
January 05, 2009, 01:07:42 AM »
The firing order is the same on all older small blocks but when GM came out with the 3rd gen small blocks (1997 LS series engines) the firing order was changed to 18726543.
Logged
Russ
Hero Member
caretaker of 1971 LT1's 11130 & 21783
Reply #3 on:
January 05, 2009, 01:42:02 AM »
Do they run smoother with that firing order?
Logged
Hero Member
owner since 4-Apr-1976
Reply #4 on:
January 06, 2009, 04:48:29 PM »
Your first gen engine wouldn't..
Logged
72 El Camino, '55-'56-'57 Nomads, '55-'57 B/A Sedan
CRG Member
Reply #5 on:
January 07, 2009, 06:07:06 PM »
The revised LS firing order swaps 4&7 and 2&3, which evens out the firing pulse forces on the crankshaft and reduces cooling "hot-spots" between adjacent cylinders; results in more stable idle and reduced crankshaft torsional deflection.
Logged
tom
Hero Member
Reply #6 on:
January 07, 2009, 09:10:44 PM »
I expect the firing could be changed with little more than a cam swap, and moving the wires. MANY years back a friend of mine had a sbc in VW Beetle. He had a cam that allowed the engine to run backwards, and drive the VW transaxle.
Logged
69 X11 Z21 L14 glide
o
Print
Pages: [
1
« previous
next »
General Discussion
