Author Topic: 1969 Z/28 Belt  (Read 14584 times)
jl8dale
1969 Z/28 Belt
« on: December 29, 2008, 10:09:30 PM »
Does anybody have a brand name and part number for the belt used on a 1969 Z/28 without smog. It runes the crank pulley, water pump pulley, and the alternator. I am being told by my supplier that he doesn't have one and doesn't know where to get one.
I believe I bought one for one of my other Z's many years ago at a local Napa but I don't remember anymore.
1969 Z/28 Daytona Yellow/Yellow Houndstooth, Tilt, Fold Down Seat, - POP
CVKUEBER
Re: 1969 Z/28 Belt
« Reply #1 on: December 29, 2008, 10:49:49 PM »
The only part number in the GM catalog for 1969 302 is 9433746. I can order one for 16.00 + freight
Re: 1969 Z/28 Belt
« Reply #2 on: December 29, 2008, 10:52:22 PM »
You need the belt for the a automatic 350, it has no smog.
CVKUEBER
Re: 1969 Z/28 Belt
« Reply #3 on: December 29, 2008, 11:40:56 PM »
350 a/t with 42 amp gen would be part# 9433741. Still available from GM. I  can still order that as well. Pm me.
tom
    • Discount Internet Services
Re: 1969 Z/28 Belt
« Reply #4 on: December 30, 2008, 04:01:03 PM »
You should be able to cross the GM number to most other belt suppliers. A functional belt may be available over the counter at your local parts supplier.
69 X11 Z21 L14 glide
o
jl8dale
Re: 1969 Z/28 Belt
« Reply #5 on: December 30, 2008, 04:30:23 PM »
Thanks guys, that's what I'll do.
I'll probably go to a Napa and buy a few and see which one fits.
It just seems extremely odd to me that this part does not seem to be known to camaro suppliers.
tom
Re: 1969 Z/28 Belt
« Reply #6 on: December 30, 2008, 04:43:10 PM »
Gates web site cross references 9433741 to 7440, and
9433746 to 7465
o
Re: 1969 Z/28 Belt
« Reply #7 on: December 30, 2008, 05:08:57 PM »
Rick's First Gens does list the shorter belt as an alternate for a Z without smog... or they did a few years ago.
GaryL
  • Marilyn and me
Re: 1969 Z/28 Belt
« Reply #8 on: December 30, 2008, 07:13:32 PM »
It is a SB automatic w/o AC belt.
Gary
Re: 1969 Z/28 Belt
« Reply #9 on: December 31, 2008, 03:31:25 PM »
The Camaro suppliers probably don't list it, as it was never catalogued as a GM usage - there was no such thing as a Z/28 without an A.I.R. pump.
jdv69z
  • 69 RS Z/28 52E
Re: 1969 Z/28 Belt
« Reply #10 on: December 31, 2008, 03:51:54 PM »
I actually changed from one length belt to a longer one on my Z w/o AIR. Alternator was almost to end of adjustment slot on the one I had, so I went To NAPA and asked for one 2 or 3 inches longer than the one I had with me. They were able to look the belts up by length. And now the alternator is closer to the center of the adjustment range.
Jimmy V
Jimmy V.
GaryL
  • Marilyn and me
Re: 1969 Z/28 Belt
« Reply #11 on: January 01, 2009, 10:15:25 PM »
What I was saying is the correct belt length is the same for a SB, automatic w/o AC. That gives you a 302 w/o smog pump length.
Gary
jl8dale
Re: 1969 Z/28 Belt
« Reply #12 on: January 01, 2009, 10:30:23 PM »
I confirmed today by looking at one of my other Z's that it is a GM Restoration Belt B-442.
Thanks for all of your help.
RamAirDave
    • TheMuscleCarGuys.com
Re: 1969 Z/28 Belt
« Reply #13 on: January 02, 2009, 04:40:59 AM »
Yep, B-442 in Rick's: Alternator belt, SB w/o A/c, with A/T (also fits Z28 if no smog installed)
Quanta belt, but obviously would have the wrong # for a Z.
www.TheMuscleCarGuys.com
