Author Topic: What's This Air Cleaner Assy worth?  (Read 10810 times)
red69
« on: December 24, 2008, 03:17:44 PM »
Any ideas on the value of an NOS air cleaner assembly for a 69 Z. Circa 1976.  It also has the seal and adapter plate.
Re: What's This Air Cleaner Assy worth?
« Reply #1 on: December 24, 2008, 06:32:07 PM »
Is it a flat bottom or does it have a ridge in the bottom.
red69
« Reply #2 on: December 25, 2008, 04:20:28 AM »
I'll find out. What do you mean about a ridge ? I'm not too familiar with cowl air cleaners
 Pat
« Reply #3 on: December 25, 2008, 02:21:19 PM »
it will either have a flat bottom or a 3/16" or so deep and 3/4" wide or so ridge around the circumference
red69
« Reply #4 on: December 28, 2008, 02:41:31 AM »
Looked at the air cleaner today. It is part number 648591. It has ridge  around the bottom. The element has a  screen with square holes A212CW. The adapter for the cowl seal is part number 3975986 or 06. Is the flat bottom desirable? Or were the originals indented? One more thing the top is Black weren't the cowl hoods supplied with chrome tops?
   Thanks Pat
« Reply #5 on: December 28, 2008, 03:10:20 PM »
   Thanks Pat
Pat - The original bases were flat on the bottom, and the air cleaner lid was black.
« Reply #6 on: December 28, 2008, 04:12:42 PM »
If the square mesh chicken wire 212 has the soldered joints it is worth a bundle on it's own.
red69
« Reply #7 on: December 28, 2008, 06:06:33 PM »
Thanks for the info, they must have changed the design of the bottom of the air cleaner pretty early, the box that this ones in has a date of 1973 on it. Back to the original question, what's it worth?
   Pat
« Reply #8 on: December 28, 2008, 08:57:32 PM »
Yes they did change the design early... before the end of 69 Camaro Production.
The NOS element if as I described before (soldered chicken wire style horizontal pattern) is worth a bare minimum of a 200-300... element alone... could be higher if it is the more valuable one... I don't remember which ones really bring the big bucks if it is the diagonal squares or the horizontal ones. I believe the hoizonatal is correct for 1970-71 up... open element, cowl induction most performance air cleaners etc. the value would be the vette and HP camaro aps for the element.
ILast one on Ebay I saw... NOS ridge bottom a/c's go for approx 1500 w/out correct element.
Again this A/C is correct for late (aug or later) 69 Camaro Cowl Induction Solid Lifter Aps and I believe it is correct for 1970 Chevelle solid lifter Cowl Induction Cars as well.
« Last Edit: December 28, 2008, 09:04:58 PM by firstgenaddict »
red69
« Reply #9 on: December 28, 2008, 10:16:47 PM »
Thanks for the info
  Pat
« Reply #10 on: January 06, 2009, 04:56:08 PM »
My Sept '69 (09C) build Z28 came with the flat bottom cowl A/C....
samanatoo
  • 69 Z28 Hugger Orange/Orange Houndstooth
« Reply #11 on: January 08, 2009, 03:03:19 AM »
My 08C August 1969 build Z has the flat bottom as well.
