I found that the gasket, is only part of your problem..
You need to use a slight bit of sealer were the lens meets the metal housing.
I went down this road before, I took the entire housing off and filled it with water were the bulbs would nomaly go, only to watch the water to run run out.
Look very carefully at were it us leaking you will be suprised.
