Author Topic: 1968 Horns  (Read 11877 times)
CVKUEBER
1968 Horns
« on: December 03, 2008, 11:11:25 PM »
Does anyone have good photos of how the horns are mounted on both a 68 standard and r/s car? Closeup pictures would be helpful. The assembly manual is not to clear. Thanks in advance, Cory
Re: 1968 Horns
« Reply #1 on: December 06, 2008, 08:45:35 PM »
E-mail sent with Photos of a 67 SS/RS.
Hope that it helps.
shuboxx55
Re: 1968 Horns
« Reply #2 on: February 10, 2010, 09:23:02 PM »
Did you ever get a conclusive answer, I'm presently changing an RS back to a standard grill on a 68, and I had the same question, as the book doesn' t have very good pics, and its not 100% clear whether its referring to a RS. Shows mounted on center bracket and also on the drivers side radiator support?
CVKUEBER
Re: 1968 Horns
« Reply #3 on: July 23, 2013, 07:16:15 PM »
No, I have not. Still hoping someone will post pics.
Re: 1968 Horns
« Reply #4 on: July 23, 2013, 09:49:51 PM »
Wow this thread has been risen from the dead.  Lol. Maybe this will help.
RS
Standard
joesauer
Re: 1968 Horns
« Reply #5 on: July 24, 2013, 02:51:25 PM »
RS mounts on the center support, non RS mounts on the drivers side of radiator support.  Horns, and attached mounting brackets, are the same for both installations.  Assembly manual shows correct mounting method for both setups.
Re: 1968 Horns
« Reply #6 on: July 24, 2013, 07:49:19 PM »
 Are '68 horns mounted the same as '67? If so I can send pics from a '67 RS/SS survivor.
Re: 1968 Horns
« Reply #7 on: July 24, 2013, 08:08:07 PM »
67 & 8 used the same horns for RS as far as I know.
DAVEN1256
Re: 1968 Horns
« Reply #8 on: July 25, 2013, 02:00:46 AM »
This is where they were on my car. I can't verify that this is the factory location, though. I had my front end apart many years ago and could not say now if the horns were put back correctly. My location differs from the photo posted by cook_dw. Maybe someone could tell me if mine were in the wrong place.
Re: 1968 Horns
« Reply #9 on: July 25, 2013, 02:56:02 AM »
According to the 68 factory assembly manual UPC 12 A8 - main shot shows the upper horn (low) & then the view B is the lower horn (high ).  Also the photo I showed of the standard headlight is an original unrestored car.
rare396bronze
Re: 1968 Horns
« Reply #10 on: July 25, 2013, 04:06:53 AM »
Just verified in 67 assemly manual horns 67-68 rs are mounted on center latch support see page 426 & 427 fpr picture. Good job cook your dad trained you well!
Re: 1968 Horns
« Reply #11 on: July 25, 2013, 10:57:36 PM »
