Author Topic: rear wheel size and backspace  (Read 7612 times)
jonboy1216
« on: November 17, 2008, 05:15:50 AM »
what is the largest tire and rim combo can a stock 68 non tubbed car hold without rubbing?
PANTHER-BUFF
Re: rear wheel size and backspace
« Reply #1 on: February 17, 2009, 01:09:12 AM »
I have 17 x 7 fronts with 4.5" backspacing, 17 x 8 rears 4.75" backspacing, backs rub slightly when car gets twisted on incline - no biggey
Try this:
http://www.camaros.net/forums/showthread.php?t=100853
https://www.rsracing.com/tech-wheel.html
http://www.miata.net/garage/tirecalc.html
http://www.1010tires.com/TireSizeCalculator.asp
Hope this helps!!
Danny
Danny
ChevyThunder
    • Pro Racing
« Reply #2 on: May 29, 2009, 03:15:09 PM »
plenty of great info on the Team Camaro site
http://www.camaros.net/forums/forumdisplay.php?f=17
1969 X44 COPO
1969 X33 RS Z/28
hotrod68
  • almost finished
« Reply #3 on: May 30, 2009, 03:32:06 AM »
I have 15x9 Pro Stars, 4.5" backspace with 11.5x28 Hoosier street slicks on mine. The tires kiss the inner fenderwells on turns, but like buff said--no biggie. A 1/2" spacer would cure it easily There is plenty of clearance at the outer lip, where all the trouble is usually caused by positive offset. Hope this helps!
jonboy1216
« Reply #4 on: June 01, 2009, 04:14:58 AM »
thanks for the info
