Author Topic: ..STUPID QUESTION..????  (Read 7941 times)
666 the legend
« on: November 15, 2008, 10:00:03 PM »
..are the 67-68 RS fenders the same as a standard camaro fender???
67 SS/RS Royal Plum 4 speed...
68 Impala Custom
68 Nova [ Yenko Clone]...
69 HURST/OLDS...# 57...
72 Trans/Am.. 4 speed..
73 Plymouth barracuda
x77-69z28
Re: ..STUPID QUESTION..????
« Reply #1 on: November 15, 2008, 10:26:09 PM »
first, the only stupid question is the one you dont ask. the fenders are different. there are brackets in the front to bolt in the rally sport headlights. that being said, you can get the brackets repro and have them welded in, if you have a line on clean regular fenders.
buddy
666 the legend
« Reply #2 on: November 15, 2008, 10:49:23 PM »
....Ah..!! so they are different......?? Thanks alot...
68 Impala Custom
CVKUEBER
« Reply #3 on: November 16, 2008, 02:42:35 AM »
The head lamp mounting bracket is mounted about an inch and a half deeper on the front opening of the fender. The brackets are easliy changeable by drilling and welding. Pretty easey actually. Other than that the fenders are the same.
sdkar
« Reply #4 on: November 16, 2008, 04:01:52 AM »
I have converted new repro 67-68 fenders from standard to RS with these brackets.  It was a quick and simple task.  I did not havve access to a welder at the time and I used a couple of large heavy duty rivets on each side and they worked perfectly when I was done and I never experienced any problems the entire time I owned the car.
On the lighter side, my old college professor used to say, there is no such thing as a stupid question, just stupid people.  Not many people asked questions in his class after that.
Brandan
  • 1969 Camaro SS 396 X-66 M22
    • 1969 Camaro 396 SS M22
« Reply #5 on: November 17, 2008, 02:56:19 PM »
so the standard fenders have the brackets as well?  for some reason I thought that the brackets were only for the rs?  sounds like here they both have the brackets and the rs are back towards the firewall more?
Check out the 1969 ride!!!
http://www.cardomain.com/ride/676916/1
Check out the new project!!!
http://www.cardomain.com/ride/2960049
x77-69z28
« Reply #6 on: November 17, 2008, 05:36:21 PM »
IT IS A DIFFERENT BRACKET FOR THE RALLY SPORT
Brandan
« Reply #7 on: November 17, 2008, 10:00:31 PM »
CVKUEBER
« Reply #8 on: November 19, 2008, 05:15:47 PM »
Those are ralley sport fenders, they will only accept the r/s grille unless you remove the brackets and weld in the ones for the standard grille.
