Author Topic: Forgive me if this is the wrong place for this, old POSI question  (Read 3233 times)
newbiee101
This is just a general question about the axle, application isn't a problem. How to get it road worthy is.
Got a '75' 8.875" MP POSI 10bolt cover 12bolt carrier.
Am told finding aftermarket gears is a no go.
" The rear in question is known as the 8.875" MP series rear.
The '71-76 version is a descendent of the '65-70 8.875 P series (big Pontiac) r/e. There is also a '77-85 version. From disassembling each version, ring & pinions will not interchange between the 3 different versions, & there are no aftermarket gears that will fit. '71-74 Pontiac B series wagons, Bonnevilles, & Grandvilles with mountain performance or factory towing pkg. Also, all GM '73-76 A-body wagons used the '71-76 MP series r/e. '73 & '74 versions with a factory towing pkg is your best bet."
Beyond the gears can the POSI be rebuilt?
Was told it had near 90,000 when pulled but worked flawless.
Change fluids, add posi addtive and go or?
