Author Topic: Coonling System Numbers Wrong on '69Z  (Read 6957 times)
DZ302 Chevy
« on: November 08, 2008, 10:16:56 PM »
I pulled out the motor from my 10C Los 69Z for one "last" time, to re-install the origional 186 heads, and check the parts against Jerry MacNisch's book.  I found nearly everything matches.
EXCEPT
The Number on the Fan is wrong according to the book.  It is suppost to be 3947772, but is 3937779 with a date code of H68.  Do I need to find a 3947772 ?
The Radiator doesn't have a tag on the radiator.  The tanks are stamped CB and IH.  There is a tag on the core that the bottom line seams to read IC 1869,  I cannot make out the top line.   Is this also wrong?
Re: Coonling System Numbers Wrong on '69Z
« Reply #1 on: November 09, 2008, 04:06:36 PM »
jdv69z
  • 69 RS Z/28 52E
« Reply #2 on: November 09, 2008, 05:31:31 PM »
Interesting.....my 10B (Oct 68) Z has 772 fan. your 10C Z has 779 fan. Must be about the time of the changover?
Jimmy V.
Jimmy V.
« Reply #3 on: November 20, 2008, 06:02:05 AM »
REading this .. I got curious (even though it's almost midnight).. I went down to the garage and disassembled my original fan/clutch, and found the CV Eaton clutch (the one shown for L78/COPO in CRG, along with an unstamped 7 blade fan... My car is a September 1969 build (09C)... with engine components from the last week of August.
jdv69z
  • 69 RS Z/28 52E
« Reply #4 on: November 20, 2008, 01:31:29 PM »
Update on my fan. Thought I had original fan, but know now I have replacement, not 772 unit. Disregard my previous comment.
Jimmy V.
Jimmy V.
