Author Topic: Muncie trans from Oldsmobile has odd switch on forward shift arm..  (Read 4772 times)
Camaroon
Curious if anybody knows what the switch mounted on the side plate of Muncies used in Oldsmobiles (and possibly other makes) around 1971 is intended for.
The switch is screwed into the plate of the Muncie where the most forward shift arm stud enters the side cover.
This was observed on a 1971 Olds 442 with 455 engine and Muncie 4 speed.
Thanks!
JoeC
Re: Muncie trans from Oldsmobile has odd switch on forward shift arm..
« Reply #1 on: November 05, 2008, 02:26:43 PM »
probably part of the TCS emission system
« Reply #2 on: November 05, 2008, 04:31:11 PM »
That switch activates a vacuum relay that allows vacuum to the distributor when the transmission is in 4th gear; part of the TCS (Transmission-Controlled Spark) system.
Camaroon
« Reply #3 on: November 05, 2008, 06:33:20 PM »
Thank you, gentlemen.
Have a great day.
 :P
