Author Topic: Water Pumps 3782608 and 3782609 casting dates??  (Read 21004 times)
opelitis1
« on: November 04, 2008, 07:12:09 PM »
Did GM put date codes on old water pumps and where..  Lotsa "Bubba" rattle can paint on the
2608 unit but I can make out a 6 with an "M" in a square.
On the other pump,  I see a "GM 3" on the front, and when I turn it over "S3" is  stamped on the rear..  The 2609 pump has a fitting somewhat like a BBC on the middle of the pump and the 2608 pump has a fitting 45 degree angled to the psgr. side...
Any idea of the dates of these beasts and, what is best way to clean these e.g. media blast without marring the pumps...  Thanks!!  T.
Re: Water Pumps 3782608 and 3782609 casting dates??
« Reply #1 on: November 05, 2008, 04:53:50 PM »
Saginaw-cast 608's usually have the date code on the front of the driver's side leg, and Tonawanda-cast 608's usually have it directly below the weep hole in the snout. A raised "S" on the engine side of the casting (inside the pump, in the impeller area) says it's a Saginaw casting.
« Reply #2 on: November 05, 2008, 08:11:22 PM »
Is there a source for seals and *Rebuild Kits* for such original water pumps?
opelitis1
« Reply #3 on: November 06, 2008, 11:36:06 AM »
Thanks encore John!!!  What is the besy way to clean the pumps??  If media blasting - what kind??  Is the Saginaw pump a Vette unit, C2, maybe and why was the fitting placed on the top akin to a BBC pump?  T.
Pacecarjeff
    • pacecarjeff.com
« Reply #4 on: November 06, 2008, 02:50:47 PM »
Water pumps were not dated until November 1965.
Pumps prior to that will not have a date code.
the 608 pumps were used as early as 1964
609 was used as early as 1957.
« Reply #5 on: November 06, 2008, 03:30:00 PM »
The 608 pump was used on lots of SB applications for many years, including Corvettes. The boss and fitting at the top of the other pump was for a bypass hose to the front of the intake manifold; all 1963-67 carbureted small-block Corvettes with aluminum intakes and 63-65 fuelies used the intake bypass hose.
opelitis1
« Reply #6 on: November 06, 2008, 09:18:49 PM »
Thanks John and PacecarJeff for this great info..  I appreciate it!!! Ted
Pacecarjeff
    • pacecarjeff.com
« Reply #7 on: November 07, 2008, 04:15:45 PM »
Pretty sure you can't read the date when installed.
You can see only that there is a date there, or not.
So pretty much any dated pump will do for your Camaro.
bc69
« Reply #8 on: June 18, 2014, 03:46:12 AM »
Can on sag's but not on ton's
Brad
RSSS
bc69
« Reply #9 on: June 18, 2014, 03:50:36 AM »
My question is about which is correct and is there a preference as to sag or ton as well as date codes?
Brad
RSSS
« Reply #10 on: June 19, 2014, 04:27:59 PM »
For Z/28's, they have to be Saginaw castings; for everything else, the block and water pump have to be from the same foundry source (the engine plants machined/manufactured the water pumps from raw castings).
bc69
« Reply #11 on: June 19, 2014, 04:53:35 PM »
So V1207MU would use ton 308 with date code maybe around L?6
? . Sound about right john?
Brad
RSSS
« Reply #12 on: June 20, 2014, 07:40:17 PM »
That's a Flint engine, so it needs a Saginaw-cast water pump, late November to very early December.
bc69
« Reply #13 on: June 24, 2014, 01:47:06 PM »
Ok thanks johnz. Wires crossed on that one. On the hunt!
Brad
RSSS
bc69
« Reply #14 on: July 12, 2014, 12:44:06 AM »
Found this one that should work.
Brad
RSSS
