Author Topic: speedometer gears  (Read 4395 times)
incom5633
speedometer gears
« on: November 03, 2008, 06:55:35 PM »
hi,
would someone be able to give me the correct speedometer gear numbers and teeth / both drive and driven for the following set-up?
1969 camaro 350ss car - 14" f70; 350 turbo trans. 3:31 posi.
big iron
Re: speedometer gears
« Reply #1 on: November 03, 2008, 08:17:52 PM »
One procedure you can do is go to gaugeguys.com and click on test. This procedure takes out all the variables like tire dia.
Hope this helps!
Bob
