Author Topic: breather hose filter  (Read 17625 times)
« on: October 31, 2008, 01:20:36 PM »
Is this breather hose filter discontinued or am I mistaken? Thank you.
Charley
Re: breather hose filter
« Reply #1 on: October 31, 2008, 03:53:44 PM »
I bought several from Chevy a couple years ago.
« Reply #2 on: October 31, 2008, 03:59:55 PM »
What was the specific year and engine usage for that part? It's clearly a flame arrestor, and that function was served on most Corvettes by a fine mesh screen press-fitted on the end of the elbow inside the air cleaner.
« Reply #3 on: October 31, 2008, 04:16:33 PM »
I don't know. I found it with my NOS parts and referenced it in a catalogue which stated it's discontinuation. It is obviously not applicable to my 327 and thought it belonged with a different hose configuration. Or even if it pertained to Camaros.
« Reply #4 on: October 31, 2008, 04:30:46 PM »
Almost looks like it might go on a power brake booster.
« Reply #5 on: October 31, 2008, 04:41:47 PM »
 Connection OD is 11/16. It's in Rick's cat. page 254.
Charley
« Reply #6 on: October 31, 2008, 07:44:02 PM »
I believe it's last application was on a truck. I will try to dig one out for a part # I know the parts places were removing the part #.
Charley
« Reply #7 on: October 31, 2008, 07:56:49 PM »
found em
« Reply #8 on: November 01, 2008, 02:59:33 PM »
The only Camaro application I can find for a separate flame arrestor is the '68-'69 RPO KD5 Heavy-Duty Closed Positive Crankcase Ventilation, but it used P/N 3924544 for all usages. All other crankcase vent systems used the fine mesh arrestor inside the air cleaner.
« Reply #9 on: November 01, 2008, 03:13:32 PM »
Part I have was manufactured by Fisher Corp.,  PAT. #3287094 ( Patent not Part) Would it's use be incorrect without RPO to substantiate?
« Reply #10 on: November 02, 2008, 04:51:20 PM »
KD5 required a plant-level rework of the air cleaner to drill the hole for the adapter elbow, install it, and plug the existing hole on the side; I doubt if many were built. I'd leave it stock.
« Reply #11 on: November 02, 2008, 05:06:32 PM »
Would this be the adapter of which you speak? There is no part# embossing.
Charley
« Reply #12 on: November 02, 2008, 07:33:12 PM »
The ones I posted were the ones they sell you to use with a crossram setup.
« Reply #13 on: November 02, 2008, 09:17:10 PM »
Would the one I posted be an OTC replacement?  Charley, do yours have a GM part# on them? My arrestor has only the info above. If indeed it is for a crossram set up or unusual substitution as John indicates, mine would not be technically correct because it has no GM part # on it, no? If yours in fact do.
Charley
« Reply #14 on: November 02, 2008, 09:34:36 PM »
Mine have no part # on them.
