Author Topic: Dynamat and other sound heat and vib mats: Compare  (Read 13532 times)
newbiee101
« on: October 30, 2008, 06:15:58 AM »
So who all is using Dynamat sound heat and vib mats???
Anyone using other brands???
Man are them things pricy.
$28 for 2 10"x10" pieces of Dynamat
http://www.dynamat.com/store/store-car.asp
Some roll on crap
http://www.quietcar.net/?gclid=CKvz9...FQIWFQodaVy9HQ
Stuff called 2nd skin that is pricy like dyna
http://www.secondskinaudio.com/
And I found smitty mats about 1/3 the pirce of them all.
http://SmittyMats.com/
Look like everyone sell the same basic stuff, those that sponsor racing and have adds on TV just charge out the BLEEP for it............ Also a friend who got dynamat form summit just the other day the salesmen said the price will be going up here soon.
Just hard to spend that much but want some comments.
newbiee101
Re: Dynamat and other sound heat and vib mats: Compare
« Reply #1 on: October 30, 2008, 06:20:33 AM »
Oops for got one
http://www.hushmat.com/new/ Performance/index.htm
Starter Kit - 4 square feet
$40.00
Thats 4 12x12 squares for $10 each, man do you know how many it would take to do the inide of my car???
That $2sqft stuff looks better and better.
Anyone have pic's they can share of a sound vib mat install in your car or what not??? And how much you spent if that not like asking a woman her age for you.
And do you really need that $15 seam tape???
-James Camaro Newbiee 101
« Reply #2 on: October 31, 2008, 06:46:34 AM »
Not sure you'll get too many answers on this one - this group tends to be more original oriented.
I did see on Team Camaro (IIRC) that some guy found a roofing material that was the same and much cheaper.
ChevyThunder
    • Pro Racing
« Reply #3 on: November 11, 2008, 08:53:54 AM »
Dynamat seems to be the only material that has consistent feedback from people who use it . I have put it in two of my cars and man does it make a differnece.
The other products .. you here about odor , some guys have put other brands in the car only to have it all come lose or get greasy .
I found the big boxes on ebay for around 100 dollars. if you search on ebay you can find good deals
1969 X44 COPO
1969 X33 RS Z/28
sdkar
« Reply #4 on: November 16, 2008, 08:04:25 PM »
So, what is the difference between them all?  Is Dyanmat, which seems to be the most popular, better, or thicker or whatever, against Smittymats, which seem cheap?  Has anyone out there done an actual side by side comparison?  I have seen articles on Dynamat, and the praise of the product, but how does it compare to the others?  I don't mind paying a few dollars more (okay, so I really do), if the item I get is actually better.  But i don't want to pay twice as much if I am getting the same result.  Any opinions from anyone that has used more than one of these items?
qwertyme77
« Reply #5 on: November 18, 2008, 01:59:24 AM »
I was wondering the same thing. I ran across the following when I was doing my research. I hope this helps.
http://www.sounddeadenershowdown.com/
paul.
69houdini
  • 69 SS X55 Butternut Vert / 68 Z28 Rally Green
« Reply #6 on: November 18, 2008, 03:03:16 AM »
I am getting ready to install acousta mat. It comes in a kit formed and measured. I ordered it for my 69 convertible Camaro. Cost about 500 bucks but I here well worth it. We'll see, I hope so.
        69 Houdini
2-68SSConverts
« Reply #7 on: November 30, 2008, 10:03:31 PM »
I just ordered and received "BXT RAAMat" to install in my 68 Convertible.  I looked at a lot of different materials but this one seemed to be the best value.  I will post pictures as soon as I get it installed if anyone is interested.  The price was about 3rd of Dynamat and it looks a lot like Dynamat except it comes in a roll.  Check out the following web site..
www.RAAMaudio.com
ChevyThunder
    • Pro Racing
« Reply #8 on: December 02, 2008, 06:47:17 AM »
On the Lateral -G site and Protouring site there are in depth discussions about this subject... all I can tell you is that it is a ot of work to do it right . I used a little wood roller , the handle of a screw driver and a blow drier on occassion, to install Dyanamat....
Here is one of the threads on Lateral-G but I would use the search function to find out more  http://www.lateral-g.net/forums/showthread.php4?t=10247
There are a bunch on Protour just use the search function and try "sound deadner" or dynamat
http://www.pro-touring.com/forum/showthread.php?t=4388&highlight=sound+deadner
Personally you hear a lot of people praise different products then you will hear someone say that same product didn't work for them . Dynamat was the only one that everyone said worked great but the big complait was the price. I went through this about two or three years ago so maybe something has changed but these are good sites to use the search function and do your homework
1969 X44 COPO
1969 X33 RS Z/28
sdkar
« Reply #9 on: December 05, 2008, 01:17:07 AM »
I used to be a roofing contractor and I used a commercial roofing product that was called modified bitumen torch grade smooth.   The torch grade meant it had asphalt impregnated into the polyester mat.  The smooth meant it did not have the ceramic granular surface, which is the same as you would see on shingles.  I ordered vehicle underlayment kits from four different suppliers, including Rick's and NPD out of curiosity to see what they used and what I have received is either this exact stuff or the thinner non torch (no asphalt) material that was cut into the pattern of the OEM underlayment.  However, you can get this stuff at any roofing supply house for about $35 for a roll that is about 33' long and 3' wide (about 100 sq. ft.).  It does not have the foil backing, but I have heard that the stuff for up north and for trailer homes is similar but does have the foil back.  Since I was a roofing contractor in Florida, I did not get into the "ice dam" roofing materials nor did I do mobile homes or trailers.  Hope this info helps.
newbiee101
« Reply #10 on: December 05, 2008, 07:13:34 AM »
I came across these codes if anyone could use them.
I was please with how it worked.
http://SmittyMats.com/sell/
10OFF $10 off order of $84 or more
20OFF $20 off orders of  $185 or more
L78 steve
« Reply #11 on: December 19, 2008, 03:28:28 AM »
I use rool roofing for trailer homes .It has a mat of asphalt with aluminum sheet on one side .It's a quarter the price and the same as the other stuff .Same weight as the factory deadner but alum. instead of the paper .
69 Z/28 Dover White. SOLD
