69 Z Clutch Fan
Started by jdv69z, October 23, 2008, 03:25:34 PM
jdv69z
Was there a sheet metal piece covering part of the clutch on these fans? Mine looks similar to the picture of the Eaton type clutch shown in the CRG report, but I have an inner circle of fins visible on mine, like mine cover piece is missing? My outer circle of fins looks identical.
Jimmy V.
Jimmy V.
sixt9x33rs
'69 RS Z/28 65B, 711 Flat hood no spoiler, endura, 4:10 44K miles (Sold)
jdv69z
After much playing with photo shop, here's a pic.
Jimmy V.
Jimmy V.
hihorse
never seen one of these. Is there a part number or date code on the flange?
Pacecarjeff
That is a late model part - early 90's
jdv69z
Quote from: Pacecarjeff on November 09, 2008, 07:03:46 PM
Do you mean part is from the 1990 or later?
Jimmy V.
Jimmy V.
Pacecarjeff
Typically I see that clutch on cars built in the 90's.
Bet if you went into the dealer for a new clutch- that is what you would get.
jdv69z
Could be the case... It's been on my car since at least 1982, so if it's a replacement, it's been in use for a while. Part no. / date stamp on flange where it's bolt to water pump? On front or back?
Jimmy V.
Jimmy V.
Pacecarjeff
So I am off by 10 years.  ::)
I always see that clutch on a lot of the late model cars.
It was a factory part-- not sure about the date - I never saved any of those.
That's a Delco clutch - rarely seen on 1st-gen cars; most used Eaton or Schwitzer clutches, and the Schwitzer clutches are dated on the O.D. of the flange where they bolt to the water pump.
jdv69z
Is it possible that it is the original, or is it a replacement? 90% of everything else on the car is original, so I never really thought about it being non original until I saw the pics of the others in the CRG report, and noticed it looked different. Can I see date on flange w/o removing it?
Jimmy V.
Jimmy V.
Pacecarjeff
#11
How many blade rivets? - looks like the fan is replaced also - got a better picture?
Some of the clutches were dated under the water pump - on the back.
Have seen Delco clutches used in the 60's - usually on Olds and Caddy - but not that face design - That is absolutely a replacement
jdv69z
You're right, fan is different. 3 rivets holding blade. Here's a pic of #'s on blade also.
Jimmy V.
Jimmy V.
Pacecarjeff
Yes,  later fan too - dated Dec 1977.
jdv69z
Thanks for the help; Interestingly, water pump and radiator are original. Wonder what would cause replacement of this, especially the fan itself?
Jimmy V.
Jimmy V.
