Author Topic: 1969 Z hood stampings/dates markings locations  (Read 29041 times)
samanatoo
  • 69 Z28 Hugger Orange/Orange Houndstooth
« on: October 22, 2008, 10:49:38 AM »
looking to see if my cowl hood is original can anyone tell me where  I can find the dates and numbers please and hoe to decode.
black69
    • my_car
Re: 1969 Z hood stampings/dates markings locations
« Reply #1 on: October 23, 2008, 06:04:47 PM »
if it helps, I found a number on my original paint black cowl induction hood, over on the drivers side hinge area on the edge of the hood. its on the side lip. my car is a 6A car and the number on the hood was 20. I can see how this could get covered during a repaint. If you ask me, if you have a numbered hood that has some week number relevance not too far off the week the car was built, it would be my 2 cents its original to the car.  for me if my car was built on the 22-23rd week of the year, and the hood has a 20 on it, my guess 20 stands for the week the hood was made (speculation on my part).
bob
Black 69L78. 4:10, RS/SS/ZL2, 'black painted tail panel different than body','red hockey stripe w/ v-top exception'
Blue 68Z28. 4:10, Kustom 'tunnel tube' headers, Nickey sold.
samanatoo
« Reply #2 on: October 23, 2008, 06:32:35 PM »
Thanks, before I started to rip off the hood insulation on my car I thought I would ask first. I see that my cars  hood had hood pins at some time and were welded and filled later on. The third owner said it had pins when he owned it and that was in the late 80's to early 90's SO??????. I will check tonight my car is a 08C car build actually built 8th 9th or 10th of August 1969, 08B was skipped.
Daytona Yellow 69 Z/28
« Reply #3 on: October 31, 2008, 10:30:02 PM »
Sorry to hijack the thread but my 69 Z/28 is also a 08C. Is it really true they skipped 08B?
samanatoo
« Reply #4 on: November 01, 2008, 12:41:47 PM »
08B was skipped!! Johnz and Kurt and a few others on the site informed me of this.  You can find out aprox what day of the month your car was built by taking the last six numbers of the vin and place them in the slot. In Jerry's book he has a break down of what number cars were built in each month and I think the list is on this site as well.  They built a certain number of cars each 24 hour shift so you can break the numbers down ti find out what day your car was built.
Also in August is when they had to last minute extend the 1969 production due to the cancel of the new 1970 Camaro so check your car to see if some parts have older dates then the norm.     My motor is a May 30th build with may 26th castings date on the block putting a 2 month span where the norm is 1 to 4 weeks.    My heads are casting date May 27th. let me know what you find I did a tom of research and recently found my pastial vin stampings by the oil filter and posted the pics my last six are 672077
« Reply #5 on: March 03, 2010, 06:46:13 PM »
Thanks, sorry to dig this back but I just stumbled back on to the thread.
My 08C Z/28 is just 219 units before yours and also has a wide spread on the block. It was assembled on June 4th and has V0604DZ on the pad. It also has the partial vin by the oil filter that matches the car.  the casting date is E16 9, as were the heads if I remember right.
L78 steve
« Reply #6 on: March 04, 2010, 08:10:49 PM »
Don't tear of any insulation,It's not under it.
69 Z/28 Dover White. SOLD
« Reply #7 on: March 05, 2010, 01:36:33 PM »
That is a picture I posted years ago of the repro ZL-2 I had on my 68 for a short time.
here are the originals comparison pics.
Repo..
GM hood...
another kurt s
« Reply #8 on: March 11, 2010, 02:50:24 AM »
So there are no numbers?  Just the different shape of stampings?  I was looking my hood over and found nothing.
1928 Model A Hot Rod
1936 Chevy 5 window Coupes
1955 Studebaker Pick up
1961 Corvette
1968 Camaro RS/SS 4 spd with air
1969 Camaro Z10
1974 Early Bronco
« Reply #9 on: March 11, 2010, 04:49:41 PM »
The Chevrolet date code will be on it. http://www.camaros.org/numbers.shtml#sheet
lynnbilodeau
« Reply #10 on: March 11, 2010, 10:46:41 PM »
John Berry's old car, 671208 I believe is an 08A car with a July 2 assembled motor.  It is the white car on page 92 of Jerry's book.
Dave69x33
« Reply #11 on: March 12, 2010, 03:23:55 AM »
My ZL2 hood is stamped "18", which would be the 18th week in 1969, or April 27 - May 3, based on the link KurtS provided covering sheet metal stamping and date codes.  My Z28 is a Norwood 05A build car, so the hood predates my car build date by one week.  The code is hard to see and I had to use magnifying glass to confirm the code as an 18 rather than 13.
KurtS,
Should we start a hood date code vs. car build date list similar to the data base started on the gas tank date code vs. the car’s build date?  I would be curious to see how this tracks, unless sheet metal is typically dated very close to the build date of the car.
If so, I'll start:
05A, hood code 18
Thanks.
another kurt s
« Reply #12 on: March 12, 2010, 03:04:03 PM »
Sure enough, my O5A Z10 has an 18 stamped hood also.  Its always a good feeling to find another original part is still with my car.  Thanks guys.
1961 Corvette
1969 Camaro Z10
1974 Early Bronco
rat pack
« Reply #13 on: March 12, 2010, 05:41:33 PM »
Kurt, not all GM sheetmetal has the stamps. I have some NOS 67 & 68 fenders that do not have any stampings on them. Seen many hoods w/o them also, and I use the the rear corners to identify whether they are GM or repro. If they ever change the repro corners to match the GM stuff then it is going to be pretty hard to distinguish which is which.....................RatPack.......................
« Reply #14 on: March 12, 2010, 09:54:22 PM »
Rat,
NOS is often stamped / marked differently than production parts.
Dave,
Problem is a lot of hoods have been changed over the years, unlike gas tanks. :)
