Author Topic: Door jamb pin switches  (Read 8421 times)
sdkar
« on: October 08, 2008, 09:44:06 PM »
I am building a 69 Camaro hardtop and wondering what type of pin switch I need to order for the door jamb that work the courtesy lights.  I see there are either a single pin or a double pin switch both recommended.  Which one do I need?  Also, how do these work...meaning are the single wire switches grounded and the wire is a positive that is grounded?  On the double wire switches, is the circuit opened or closed when opening the door?  Are the wires connected or disconnected when the door is open?  I think I remember reading that GM does this one way while Ford does it the opposite.  Thanks for any info.
RamAirDave
    • TheMuscleCarGuys.com
Re: Door jamb pin switches
« Reply #1 on: October 08, 2008, 11:44:39 PM »
Double in the LH jamb, single on the other side.
Can't help you on exactly how they work.
www.TheMuscleCarGuys.com
m22mike
« Reply #2 on: October 09, 2008, 12:46:23 AM »
 The jam switches are switching the ground. There is no power at the jam switches.
When one , or both doors are open the switch is closed. And providing the ground for the dome light.
 The double contact on the L/H jam switch is knothing more than a jumper that runs over to the R/H jam switch.
GaryL
  • Marilyn and me
« Reply #3 on: October 09, 2008, 02:38:43 AM »
You need to be picky on where you buy them. The Delco replacement is not correct for the double pin driver side.
Gary
RamAirDave
« Reply #4 on: October 09, 2008, 02:48:25 AM »
What is the issue with the ACD part?
« Reply #5 on: October 09, 2008, 04:32:51 PM »
The LH 2-contact switch also grounds the key buzzer circuit when the door is open.
GaryL
  • Marilyn and me
« Reply #6 on: October 25, 2008, 01:52:31 AM »
It has a plastic sleeve and a plastic button on the end. At least the Delco part I bought did. I tried twice.
Gary
GaryL
  • Marilyn and me
« Reply #7 on: October 26, 2008, 04:00:31 PM »
Here is a Delco replacement. Totally wrong.
Gary
