Author Topic: Non Radio 67s  (Read 10761 times)
YENKOL88
Non Radio 67s
« on: September 28, 2008, 02:46:30 PM »
Question for non radio 67 owners. I have 2 67s; one a radio car w/ an antenna wire running thru a hole in the door jam. The other a non radio car w/ a black rubber grommet filling that same hole. Question is did all cars get the grommet or just the non radio cars? thanks.
Re: Non Radio 67s
« Reply #1 on: September 28, 2008, 07:40:34 PM »
That hole was pre-pierced in every car - if it got a radio, the antenna cable came with a grommet on it that went in the hole. If it didn't get a radio, the hole got a solid grommet.
JWC
Re: Non Radio 67s
« Reply #2 on: September 29, 2008, 07:59:20 PM »
I believe that if a car had the optional rear antenna, that the grommet in the hole in the RH hinge pillar also had a solid grommet, as the antenna cable wasn't routed through that hole (at least my '68 is that way).
YENKOL88
Re: Non Radio 67s
« Reply #3 on: September 29, 2008, 08:56:29 PM »
Thanks, do you have a pic of the grommet, I assume its the same from 67 to 68.
JWC
Re: Non Radio 67s
« Reply #4 on: October 02, 2008, 07:03:54 PM »
I can grab one this weekend - I'm out of town until Friday.
JWC
Re: Non Radio 67s
« Reply #5 on: October 09, 2008, 12:15:28 AM »
Sorry about the delay - here's the picture.
As you can see, the PO didn't remove it when he repainted the car, so it has some (blue) overspray on it.
I looked in the '68 AIM under RPO U73.  It doesn't call out the plug.
The grommet that was used with a fender-mounted antenna is shown as POA of the cable assembly (RPO U63, sheet B1).
Hope this helps.
YENKOL88
Re: Non Radio 67s
« Reply #6 on: October 09, 2008, 01:01:58 AM »
That's it  , awesome Thanks!  it has a very small hole in the middle too.
rare4k
Re: Non Radio 67s
« Reply #7 on: October 09, 2008, 03:47:21 AM »
Also NO ground straps under the hood
JWC
Re: Non Radio 67s
« Reply #8 on: October 09, 2008, 03:44:15 PM »
No, it is a solid plug.  No hole in the middle.
It appears to be the same grommet used on cars with fender mounted antennas without the pass-through hole for the antenna cable.
Any hole there would be a direct water and air leak into the passenger compartment.
Re: Non Radio 67s
« Reply #9 on: October 09, 2008, 04:37:39 PM »
That's because the plug (on a non-radio car) was installed by Fisher Body; Fisher also installed the antenna cable on a rear-antenna car. Chevrolet installed the antenna cable on a front fender-antenna radio car.
Charley
Re: Non Radio 67s
« Reply #10 on: October 11, 2008, 05:28:50 AM »
my 67 Z28 with rear antenna grommet.
YENKOL88
Re: Non Radio 67s
« Reply #11 on: October 12, 2008, 12:54:32 PM »
thanks...If the trim tag was coded on the fisher side for rear antenna, how come it wasn't coded for nonradio if they had to put the same grommet in?
Re: Non Radio 67s
« Reply #12 on: October 12, 2008, 03:01:57 PM »
Because all cars were built to the "base" condition unless an option was specified, and not having a radio was the "base" condition; every car got the grommet unless the optional radio with the standard fender antenna was specified.
