Author Topic: Natural Metal Finish? Paint undercarriage.....???  (Read 12405 times)
Brandan
  • 1969 Camaro SS 396 X-66 M22
    • 1969 Camaro 396 SS M22
« on: September 03, 2008, 05:11:56 PM »
Looking at Jerry's book, some of the undercarriage calls for "natural metal finish".  Does anybody know of a paint that is natural metal finish?  I don't want to leave some of the steering and springs untreated.....bare metal in Florida is not a good idea..
thanks,
Brandan-
Check out the 1969 ride!!!
http://www.cardomain.com/ride/676916/1
Check out the new project!!!
http://www.cardomain.com/ride/2960049
Re: Natural Metal Finish? Paint undercarriage.....???
« Reply #1 on: September 03, 2008, 06:16:41 PM »
Yes, you can buy "Cast Blast" cast iron gray which is a Seymour paint product. Part #16-048. However, longevity and performance is increased if epoxy primer is used as a substrate.  I personally go the extra step. Your painter can mix the same thing on his system.
jeff68
« Reply #2 on: September 04, 2008, 12:12:59 PM »
You may want to look into Nyalic clear coat.  It is no longer available directly from Nyalic, but they put me in touch with DoubleHorn Products, who sells it in 4 oz. spray cans under their own name (although I am assured by Nyalic that it IS their product).  It is intended for all types of surfaces, including bare metal or plated surfaces.  Supposedly, this stuff is the best.
I have not used it on the Camaro, but I just used it to clear coat the brake calipers and undercarriage/suspension components on a new car that I just bought.  We'll see how it holds up to a New England winter.
I was worried that this clear coat would be too glossy, but it looks great.  After coating the plated brake calipers on my new car (which have a slightly rough surface texture), you can't even tell they were coated.  On the smooth aluminum diff cover, you can see a slight increase in gloss.
« Reply #3 on: September 05, 2008, 03:11:21 PM »
I use Boeshield... it works great for a car driven under 1000 miles a year...
wtexz10
« Reply #4 on: September 05, 2008, 11:57:59 PM »
I can vouch for Nyalic.  About 5 years ago I coated a freshly bead blasted aluminum intake with it and it still looks good.  I did not know that they no longer sold it direct.
Kris
69 Camaro Z10.. 72 GMC C1500
79 Mazda RX7.. 79 Trans Am WS6
06 Corvette Z06.. 10 BMW 650i
« Reply #5 on: September 06, 2008, 12:47:06 AM »
Sorry, Disregard my info. It does not apply to the type of car you are building.
Brandan
« Reply #6 on: September 06, 2008, 01:51:59 PM »
lots of good info here....... thanks.... will have some updated pics of the process soon.
buenymayor
« Reply #7 on: September 24, 2008, 02:57:17 AM »
I used Eastwoods Cast Blast powder coat on all my steering linkage. It looks pretty good, but has a little more sheen than bare cast iron. If you aren't after a points car, I was pretty happy with the results.
mrdetails
« Reply #8 on: September 24, 2008, 06:42:59 PM »
I used Eastwood Diamond clear which comes either gloss or semi-gloss. works good on bare steel or cast.
Good Luck
Brandan
« Reply #9 on: September 25, 2008, 08:00:51 AM »
I went with the Eastwood Spray Gray, for the natural metal finish.  So far so good.  More pictures soon on the site.... unfortuntely the time this is taking is long..... but I think in the end it will be well worth it....I ordered the Eastwood black/aqua for the trunk spatter and it comes with the diamond clear satin so I have my fingers crossed on the correct match and gloss.
they haven't let me down yet.. haha
