Author Topic: Clutch Return Spring  (Read 10223 times)
Rentuk
  • New Motor Going In
« on: August 31, 2008, 06:27:36 PM »
I'm installing a set of full length Dougs headers on my 1969 Camaro. Looks like the clutch return spring needs a new home. Can someone give me a heads up on some of the common points that the spring might be moved to, what's involved etc. , etc. Thanks
Stillwater Camaro
Re: Clutch Return Spring
« Reply #1 on: September 02, 2008, 11:17:57 PM »
In the past, if the header tube was in line with the spring, I just put a stainless hose clamp around the tube and attached the spring to it. Course I never had ceramic coated headers that I didn't want to scratch either.... ;)
1967 Camaro SS/RS 350
1966 Chevelle SS 396
1970 Chevelle SS 396
pdq67
« Reply #2 on: November 27, 2009, 03:48:16 AM »
That or two to three loop's of re-bar tie wire!
pdq67
« Reply #3 on: November 02, 2010, 02:53:03 PM »
I swapped the spring or extension hook end for end and it clears with Hooker Super Comps
flyingskibiker
« Reply #4 on: November 03, 2010, 02:35:23 AM »
There is a convienient hole in the frame on a '68...
L78 steve
« Reply #5 on: November 10, 2010, 03:06:35 AM »
Like what Firstgen said. It works perfect on Super Comps.
69 Z/28 Dover White. SOLD
