Author Topic: 1969 Z28 casting date on my 12 bolt is Nov 29 1968. Could be cars original rear?  (Read 12112 times)
samanatoo
  • 69 Z28 Hugger Orange/Orange Houndstooth
My  Z28 has a 2nd week of August build so could this be the cars original axle?? How close do the casting dates run to the cars build on rear ends???
L78 steve
That's quite a spread,Do you have the protect-o-plate ?I have a Nova that has long spread but the POP verifies it .
69 Z/28 Dover White. SOLD
Jerry@CHP
Gear ratios can also deteremine the time window on these cars.
Jerry
samanatoo
 The axle code Jerry is   PC 1129 G (3.31, nin posi, Nov. 29th, Detriot) Right?              K 21 8 is the cast date         3894860N cast number thanks
That's a 67 axle, so a little too early for your car. ;)
samanatoo
K 21 8   stand for  K being November, 21 the day, and 8 being 1968??
PC in 69 is a 2.56 10 bolt.
The 8 in the date is probably a 6.
samanatoo
PC code for  Non - posi Axle was for 12 bolt 69 cars I found the info on this site last week, but i will check the number 9 again, it is easy to read because the axke has non dirt or grime and fresh paint thanks! I will check it again.
lakeholme
  • 68-12D L30/M35
Samanatoo,
Decoding can be confusing... and Chevy and their suppliers used interesting and varying systems of id...
You have to read the chart all the across on the CRG Drivetrain Decoder.  The 69 #s are in the right hand columns.  Look here:
http://www.camaros.org/drivetrain.shtml#AxleCodes
Colvin verifies Kurt's decoder about 69 PC axle on page 314 of Chevrolet By the Numbers, 1965 - 69.
Kurt,
Thanks for what you and all CRG do!  This thread made me go back and re-read your decoder info. again.  I learned quite a bit!
samanatoo
I see what you mean in the far right colum and it goes by model year for the car not the calender tear. I just looked at the number 8 and it sure does look like an 8 but I guess it could be a 6, but it looks more like an 8. So they did make this PC code axle for 1966???
