Author Topic: 1969 Z/28 heater hose bracket  (Read 13557 times)
sam
« on: August 18, 2008, 02:27:49 AM »
Do all the 69 Z/'s have the bracket that bolts to the top of the alternator for the 2 heater hoses? I saw 2 survivor 69 Z/s that did not have them and my 1969 SS nova small block survivor does not either. I don't think the brackets were just left off or missing because the hole in the alternator bracket was not cut by the screw/bolt threads.  Thanks,  Sam
Re: 1969 Z/28 heater hose bracket
« Reply #1 on: August 18, 2008, 02:05:15 PM »
Not all of them have it... The Early car I am doing now has never had the threads cut in the alt bracket for the clip either...
Jerry's book shows some with and some without...
« Reply #2 on: August 18, 2008, 05:33:00 PM »
My original 02D Norwood Z/28 has the bracket.
Dusk Blue Z
« Reply #3 on: August 18, 2008, 11:13:46 PM »
My 5A Norwood, 28K mile Z does not have the bracket. No threads cut in top alt. bracket either.
1969 Z/28 Legends Certified
1969 Z-10 350 4 speed
« Reply #4 on: August 19, 2008, 01:44:07 AM »
Small-blocks that did not get the metal bracket received a black vinyl ty-wrap [also used on RS hoses] to contain the hoses and alternator harness. Excellent photo in the August 1969 Road Test magazine.
sam
« Reply #5 on: August 19, 2008, 11:40:34 AM »
Thanks guys! Seems like the couple early Z's I saw don't have the hose bracket. I guess hit and miss like some other little things in the old days.  Sam
red69
« Reply #6 on: August 19, 2008, 03:15:39 PM »
My car is 12C LA built it has the bracket
« Reply #7 on: August 19, 2008, 11:50:28 PM »
It's hit or miss... the Jan 69 Hot Rod mag test car is a very early Z and it has the bracket.
69z28302
« Reply #8 on: August 21, 2008, 05:49:42 AM »
This 7800 mile car VN (LA) car looks like it does not have it.
http://www.camaros.net/forums/showthread.php?t=138997&page=3
AFONEFE
  • Daily driver in background
« Reply #9 on: August 30, 2008, 01:16:20 PM »
My 12C Norwood Z has the bracket.
69 Z/28 X-77
"CHP, this is Chris can I help you?"
melav8r
« Reply #10 on: January 29, 2009, 06:40:04 PM »
For the cars that did have the heater hose bracket on the alt bracket, does it attach with a single bolt from the top or a stud of some type using a washer and nut?
The FAM shows a washer and nut to a stud which sticks up from the underside of the alt bracket. I've always thought it was a single bolt attached from the top, no washer no nut. If it is a stud, is that actually a bolt threaded from the underside of the bracket?
« Reply #11 on: January 31, 2009, 08:46:34 PM »
It's a 3/8" hex indented-head self-tapping screw; no stud.
Dave69x33
« Reply #12 on: February 04, 2009, 02:05:45 AM »
After consulting with Larry Christensen (well known 1st Gen Camaro restoration specialist), the self-tapping "RBW" 1/4-20 x 1/2" self-tapping screw is a common screw for this application, and considered correct for judging purposes.  A very close RBW screw alternative is available from Paragon Corvette Reproductions, Kit #11189K, for about $5.  The screws in this kit are not self tapping but a good alternative.
JohnZ...is your original screw for this application still on your 69?
Does anyone else out there have a survivor 69 with the original screw or wire tie strap still intact?  If so, please post a picture and let use know the build date and VIN on your car, to give us an idea on the assembly time frame of your car.
Many cars have this original screw missing or replaced due to the frequency of removal for belt and/or alternator replacements over the years, or due to the threads in the bracket becoming striped.
Dave
GaryL
  • Marilyn and me
« Reply #13 on: February 05, 2009, 04:01:28 AM »
http://www.camaros.net/forums/showthread.php?t=138997&page=18
A picture may be there on this tread over at TC. I will ask anyway.
Gary
