Author Topic: Help! Painting Monday!!!....I can't find the correct info to do this right......  (Read 21468 times)
 Thank you. I do understand paint deterioration. The different appearence between the dash and door tops of relics Ive had  is substantiated by this info. That is why I'm glad I found this site. I've done many jobs and some for people who claimed to possess a wealth of knowledge. Even about their own high $ cars.
Brandan
  • 1969 Camaro SS 396 X-66 M22
    • 1969 Camaro 396 SS M22
So what is the difference between the suede and just a regular flat black?
Check out the 1969 ride!!!
http://www.cardomain.com/ride/676916/1
Check out the new project!!!
http://www.cardomain.com/ride/2960049
Brandan
thanks for the link.....
Jerry@CHP
All 1967 upper dash boards were suede paint.  My 1967 13,000 mile survivor Z28 has it along with every original car that I've inspected and judged through the years.  This can still be bought and we stock it.
Jerry
There is a very close match to the suede paint available in a spray can... it is a textured flat finish Krylon available at Lowes.
They have two different black textured paints....The one you want is the one with "less texture" on the cap.
2.)  The trunk will eventually get spatter paint.  Black/Aqua is what I came up with for 1967.  What is under the Black/Aqua spray in the trunk area?  black primer?  Also I have read on this site that the shakers do not get spatter.  Then I read in Hoopers book that they are spattered.  Confused on this one. ???
The shakers were hung in the trunk when the trunk was sprayed. They will have splatter on them, but it will not match the splatter in the corners where they go. And the mounting bolts have no splatter.
Brandan
thanks kurt
