Author Topic: What do you use for a Coolant Recovery Tank?  (Read 11252 times)
77thor
« on: August 12, 2008, 11:19:05 AM »
Just curious...
I would like to add a Coolant Recovery Tank to my 69 Camaro and since these cars did not come with them,
I'm trying to figure out what will fit.
Re: What do you use for a Coolant Recovery Tank?
« Reply #1 on: August 12, 2008, 12:51:09 PM »
If you must have one... use an extra wiper washer bottle mounted in the position a RS would have it... Passenger side inner fender...
See it on the left of the engine compartment?
77thor
« Reply #2 on: August 12, 2008, 04:22:54 PM »
That's not a bad idea.... it has the OEM look to it.
Thanks.
no69x-44
« Reply #3 on: August 14, 2008, 08:02:25 PM »
That's what I had in my car - before I start tearing it apart for the resto.  Looked like it belonged there and work like it too.
--Rob
'72 SS Nova - Gone
'68 Chevelle - Gone
'67 Impala - Gone
'65 Belair - Gone
'00 Corvette - Still got it
'69 Camaro - Keeper
sd1968z28
« Reply #4 on: August 15, 2008, 12:42:31 AM »
i use a plastic pop bottle, run the overflow hose into it.  easy removal for shows plus id meets nhra rules!
tom
    • Discount Internet Services
« Reply #5 on: August 15, 2008, 01:06:38 AM »
Got pics of that pop bottle installed? Where is it mounted?
69 X11 Z21 L14 glide
o
RamAirDave
    • TheMuscleCarGuys.com
« Reply #6 on: August 15, 2008, 03:55:38 AM »
My buddy made a bracket to utilize a Heineken can.
www.TheMuscleCarGuys.com
hotrod68
  • almost finished
« Reply #7 on: August 15, 2008, 03:57:33 AM »
I did like 1stgen--but I attached mine next to the radiator on the radiator support with an OEM bracket. Works like a charm.
« Reply #8 on: August 15, 2008, 12:40:38 PM »
The battery is next to the radiator... the car in the photo is a RS so that is not the overflow that is the washer bottle...
77thor
« Reply #9 on: August 15, 2008, 04:42:38 PM »
That's classic :)
But hey, whatever works.
hotrod68
  • almost finished
« Reply #10 on: August 16, 2008, 12:32:57 AM »
My battery is in the trunk. Frees up a lot of room.
« Reply #11 on: August 16, 2008, 04:38:51 AM »
My car has a plastic soda-pop bottle. Just slipped in next to the radiator end tank. Fits and no bracket required.
