Author Topic: 68 Tail Light Bezels - Which Ones?  (Read 20214 times)
jeff68
Re: 68 Tail Light Bezels - Which Ones?
« Reply #15 on: September 12, 2008, 03:21:21 AM »
I just received a set of CHQ bezels from Rick's, and they are very nice.  I was pleasantly surprised with the quality.  The chrome & overall finish is very good.  My original lenses and backs fit perfectly.  If you look closely, you can tell that they are slightly different around the lens openings, but you wouldn't notice unless comparing them side-by-side to an original set. The only disappointment was that the studs are pre-threaded with a standard thread (1/4-20 I think).  The original nuts can't be used without basically cross-threading them on.  So, I will probably just use the nuts that came with the bezels.
One more question - Was anything put over the ends of the studs after they were installed (like a cap of any type)?  I never recall seeing anything and my father (original owner) doesn't either.
Thanks for all the help,
Jeff
