Author Topic: Q-Jet Date Codes  (Read 28752 times)
Re: Q-Jet Date Codes
« Reply #15 on: November 07, 2010, 02:28:58 AM »
70 = Rochester products division and since it's not really needed, some carbs were produced without it.
crobjones2
« Reply #16 on: November 07, 2010, 02:54:25 AM »
Begs the question - if 70 is a rochester plant code, why do the Carter manufactured carbs contain the 70?
Chris
69 SS 350
« Reply #17 on: November 07, 2010, 03:55:18 AM »
Carter was commissioned to produce the Rochester Q-Jet as a secondary source and therefore they would have the same ID markings.
Boston14
« Reply #18 on: November 07, 2010, 04:24:19 AM »
Here's a picture of my early 69 carb number.  The car is an RS/SS 350 (L48 w/M38) built in Norwood with an 11D (1968) Fisher body date. The carb was manufactured by Carter under license from Rochester. The date is L8 which translates to NOVEMBER 1968. GM parts with stamped date codes do not use the letter i therefore L is for November (L is December for cast parts).
boston14
boston14
1969 SS/RS 350 Convertible
IZRSSS
  • Guest
« Reply #19 on: November 07, 2010, 12:43:01 PM »
Boston14,
Our cars were built around the same time and are both L48's. What is your cars build date? Mine is 12A (Van Nuys). Can you also elaborate on your last two sentences...I don't really follow the L part?
« Last Edit: November 07, 2010, 01:42:59 PM by IZRSSS »
Boston14
« Reply #20 on: November 07, 2010, 03:03:54 PM »
GM parts with date codes applied after manufacture (carbs, alternators, starters, etc.), if they have a date code using letters for the month, are as follows; JAN = A, FEB = B, MAR = C, APR = D, MAY = E, JUN = F, JUL = G, AUG = H, SEP = J, OCT = K, NOV = L, DEC = M.  The letter I is NOT used.  GM parts with the date codes cast in them at manufacture (engine blocks, heads, intake manifolds, etc.), if they have a date codes using letters for the month, are as follows; JAN = A, FEB = B, MAR = C, APR = D, MAY = E, JUN = F, JUL = G, AUG = H, SEP = I, OCT = J, NOV = K, DEC = L.  Hope this helps.  My build date is 11D (Norwood).
boston14
boston14
« Reply #21 on: November 07, 2010, 05:51:13 PM »
It's discussed here:
http://www.camaros.org/forum/index.php?topic=7276.0
IZRSSS
  • Guest
« Reply #22 on: November 07, 2010, 07:57:01 PM »
Boston14 & John,
You had lost me with the I. Amazing...why the heck would they leave out the I. Makes no sense at all. You'd think they would have found a better way to distinguish between manufacture and post manufacture. Thanks for going to the trouble of printing it out. Now this senseless method makes sense.
Our cars were only days apart on build...cool.
Mark
« Reply #23 on: November 07, 2010, 08:11:34 PM »
Its an engineering thing.  Letters I's and O's can be confused with numbers 1 and 0, so they are not typically used when using letters to identify components where letters and numbers are used together.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
IZRSSS
  • Guest
« Reply #24 on: November 07, 2010, 09:26:55 PM »
Now it makes perfect sense.
Thanks Mark
crobjones2
« Reply #25 on: November 07, 2010, 11:39:20 PM »
boston14
Looks just like mine ( except yours seems to be a little more golden in color) made E9
Chris
69 SS 350
