Author Topic: GM 14x6 Trim Ring Quality  (Read 24847 times)
Pacecarjeff
    • pacecarjeff.com
Re: GM 14x6 Trim Ring Quality
« Reply #15 on: August 01, 2008, 08:38:09 PM »
Sorry - I was just trying to confirm the part numbers.
I did not want to sell these.
But thanks for asking.  :P
Pacecarjeff
    • pacecarjeff.com
« Reply #16 on: August 02, 2008, 07:55:43 PM »
here is the 475019.
I have a set of these - have had them a good while - they are GM
jeff68
« Reply #17 on: August 05, 2008, 10:30:53 PM »
I just ordered a set of the USA made trim rings from Classic Muscle (based on lakeholme's experience with them).  I'll report back on what they look like.
lakeholme
  • 68-12D L30/M35
« Reply #18 on: August 06, 2008, 01:00:16 PM »
I got a set from Classic Muscle a few months ago for my 68 and they look great, but I think in the long run Mark's comment about the 4 clip setup will prove true.  They fit tight at first, but I can see how they will rattle eventually.
Right now, mine are sitting on a shelf, too.  (Still, working on a prep for a re-paint.) Generally, Classic Muscle has good stuff.  Let's compare notes on the rattling issue in a year or so.
jeff68
« Reply #19 on: August 10, 2008, 06:44:08 PM »
Well, I received the set of US made trim rings and I'm not really impressed with them.  I'm going to send them back.  They would be OK for a driver I guess, but all of them have scratches on them.  The scratches are relatively small area wise, but they are fairly deep, meaning that you couldn't remove them with some metal polish by hand.  I could send them off to be re-polished, but I can't see investing roughly another $200 into these rings.  Also, the galvanized clip ring extends into the valve stem hole quite a bit more than my older GM ones, which doesn't look good at all.
Some of the scratches on the outer lip look like they were caused by improper packing.  The individual rings are just in plastic bags, then they are placed face-to-face in sets of 2.  The 2 sets are then taped together.  The problem is that the ring faces rub against each other in transit.  On mine, the plastic bags were completely worn through in spots, causing the ring faces to rub on each other.  What is weird is that each ring appears to have a scratched area in the same spot next to the valve stem opening.  Also, each ring has an area that isn't completely smooth.  It looks like there is an area of the tooling that may have some surface irregularities.
I image that I would have the same issue if I bought a set directly from GM as well.  The only problem is that my dealer says that they are 'special order' and they will not take them back unless they have significant damage.  They told me that small scratches/scuffs would be considered "commercially acceptable".
My old GM ones that I have right now still look better IMO.  I guess that I'm just too picky.  Oh well, I tried.
lakeholme
  • 68-12D L30/M35
« Reply #20 on: August 23, 2008, 12:40:33 AM »
Jeff68,
Now I feel bad about my recommendation!   :-[
Mine look fine.  Smooth, clear finish with no scratches...  I did pick them up right out of their warehouse in Winston-Salem, NC, although they were already packed in the box and wrapped in paper.
IMO, it's fine to be picky.  You're the paying customer!
