Author Topic: 68z28 speedo gears  (Read 6507 times)
sd1968z28
68z28 speedo gears
« on: July 25, 2008, 04:00:52 PM »
   i just installed the original rear axle assembly back in my car, it has 4.88 gears and holy cow what a difference.  the speedo is now off by iwould guess 10 mph.  what do i need to fix this problem.  it has 302 original engine, m21 trans and E70 15 tires.  also the shifter seams to droan now, is this common for a low gear car?
Re: 68z28 speedo gears
« Reply #1 on: July 25, 2008, 06:45:21 PM »
The engine is running at a higher RPM now so you are just not used to the sound, it is normal in a car with steep gears, you will get used to it.
The speedo will be off a percentage... not a speciifc number.
You may be able to buy the trans gear at the Chev dealer... if not there are Stewart Warner gear reducers all the time on ebay...
« Reply #2 on: July 26, 2008, 04:05:44 PM »
I don't believe there was any factory combination of drive and driven gears that worked for a 4.88; you'll need an adapter gearbox made up. Try these guys:
http://www.gaugeguys.com/ratioadapt.htm
sd1968z28
« Reply #3 on: July 28, 2008, 01:48:22 AM »
i figured i would need a box, hopefully i an get one so i don't need to take the trans apart.  this is the factory srt up so i guess they used an reduction box also?
« Reply #4 on: July 28, 2008, 04:01:39 PM »
The factory used a ratio gearbox on cars with 4.56 axles - it's shown with the drive "key" in the Assembly Manual in section G80, Sheet A2.
sd1968z28
« Reply #5 on: July 28, 2008, 04:43:43 PM »
thanks for the info.
