Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Restoration
Blast media for aluminum parts
« previous
next »
Print
Pages: [
1
Author
Topic: Blast media for aluminum parts (Read 6097 times)
Flowjoe
Member
on:
June 27, 2008, 02:49:13 PM »
I have few alternators and distributors I need to clean up prior to rebuilding...any suggestions for a blast media type (or other method) to clean up but not pit?
Tweet
Logged
sd1968z28
Member
Re: Blast media for aluminum parts
Reply #1 on:
June 27, 2008, 07:20:27 PM »
try plastic media, i have done this it work pretty good. leave clean original metal as new most times.
Logged
Hero Member
caretaker of 1971 LT1's 11130 & 21783
Reply #2 on:
June 27, 2008, 07:55:41 PM »
The best way to get the right finish is to find an aluminum foundry and ask if they will drop the parts into their vibratory media hopper (which they use to remove the sand from raw Aluminum castings) The finish is the same as the factory as that is how they got the finish in the parts to begin with.
Logged
Jerry@CHP
CRG Member
Reply #3 on:
June 29, 2008, 04:14:36 PM »
This is the same machine that we use at CHP. You have to be careful with the different medias, it took us a while to get a handle on what works best to retain an original cast aluminum look. Cycling time is also an important issue too.
Jerry
Logged
Print
Pages: [
1
« previous
next »
Restoration
