Author Topic: Drain Bolt Gasket  (Read 7703 times)
camshaftit
Drain Bolt Gasket
« on: June 26, 2008, 05:49:27 PM »
What is the original material for the oil drain bolt gasket?
Are the engine and trans drain bolt gaskets the same material?
Why use copper versus nylon?
john302
Re: Drain Bolt Gasket
« Reply #1 on: June 27, 2008, 02:17:45 AM »
plastic is original
« Reply #2 on: June 27, 2008, 10:58:20 PM »
Manual transmissions only had a fill plug (no drain plug), and it was an NPT pipe plug; automatics had no drain plug either.
Steve68
« Reply #3 on: June 27, 2008, 11:20:13 PM »
Quote
My original M22 has a drain plug (NPT pipe).
BlackoutSteve
« Reply #4 on: June 28, 2008, 08:20:28 AM »
Nylon will conform to irregularities in the pan & bolt head with much less torque than that of copper. It's much softer.
I use the nylon washer/gasket as supplied in the felpro gasket kits, and they work just fine. No leaks!
Restoring my RHD 69 Jane in Melbourne, Australia.
http://www.usmuscle.com.au/Forum/showthread.php?t=2840
« Reply #5 on: June 28, 2008, 08:53:39 PM »
Quote
Correct - original M22's had a drain plug, and all Muncies from 1970-up had one too; many pre-1970 Muncies had drain plugs added during rebuild as a convenience.
9T4Z
    • Gary's Camaro
« Reply #6 on: August 25, 2008, 10:16:12 PM »
Would someone please confirm this?   I've seen a number of TH350's with drain plugs...  don't look like replacement pans.
Gary 9T4Z
69 Pace Car, 70RS,91Z,91RS
sebastien
« Reply #7 on: August 29, 2008, 05:02:49 AM »
powerglide transmissions have a drain plug as well don't they?
Sebastien 68  327 rag top
