Author Topic: 67 SS350 Waterpump and Distrib  (Read 8886 times)
jidc
« on: February 09, 2006, 09:31:58 PM »
I am still going crazy with all the different sources refrencing different numbers
Which would be correct for a SS 350 built 1st week July Man Transmission
Water pump
3859326
with 2 threaded water lines
or
3782608
with one threaded water line
Distributor
1111264
or
1111168
Thank you for the help,it is much appreciated
Steve68
Re: 67 SS350 Waterpump and Distrib
« Reply #1 on: February 10, 2006, 01:00:24 AM »
jidc
My source shows part number 3890017 (Colvin cast number ='s 3782608) as the original water pump part number for you.  The distributor as 168.
« Last Edit: February 11, 2006, 03:29:09 PM by Steve68 »
danh3508
« Reply #2 on: February 11, 2006, 05:48:06 PM »
I agree with Steve, my research says the same
crossram
  • Guest
« Reply #3 on: February 18, 2006, 06:40:19 PM »
I know that the Colvin book does not show the 350 with the #326 water pump, but my 67 350 with A/c has the #326 pump and the top by pass hole plugged. I have not read anything written to confirm this but believe the #326 is correct for a 350 A/C car in 67. I agree that #168 is correct for the distributor, that is what mine has.
« Reply #4 on: February 18, 2006, 07:24:18 PM »
The 326 water pump was only used on applications that had an aluminum intake with a bypass fitting at the front; if it has the upper boss with a plug in the hole, it's a service replacement.
