Author Topic: 69 Who rebulids front calipers?  (Read 5287 times)
69z28302
« on: June 18, 2008, 06:18:56 AM »
Does anyone know who will rebuild 69 front calipers? I want to use the originals on the car
Thanks CRG
Re: 69 Who rebulids front calipers?
« Reply #1 on: June 18, 2008, 09:40:55 AM »
 You can. You can get the kit. I did mine (and others)12 thousand miles ago and they work fine. Inspect the bore and piston after disassembly. If not, then one of the other members can recommend someone who is reputable. Be sure to excercise safety when using air to push out piston. Not a condescending remark, just don't know if you have done them before.  Scott
