Author Topic: Drum Brake problem - help requested.  (Read 5400 times)
abozny
  • 1967 SS 350 4-Speed
« on: May 30, 2008, 05:38:35 AM »
Hi, yesterday I took my Camaro out for a drive for the first time in 6 months. The rear right drum locked up during the drive and the drum and rim became very hot. I went home.
The drum is now locked. I checked the parking brake cable and it is loose. I assume that the pistons in the wheel cylinder are stuck - maybe from corrosion / lack of use over the winter?
How can get the drum off to get to the brake internals?
Thanks for your help.
Allen.
Re: Drum Brake problem - help requested.
« Reply #1 on: May 30, 2008, 01:49:25 PM »
Sounds like you have a bad hose. Release the pressure by cracking open the bleeder valve and you should be able to get the drum off.
