Author Topic: New CRG Report on 1st Gen Carburetors - L65 Engine  (Read 26512 times)
rich69rs
  • LF7/M35/Z22/Z87
« on: May 27, 2008, 10:03:56 PM »
The attached broadcast sheet in the following link:
http://www.camaros.org/forum/index.php?topic=3932.0
was recently found on a 1969 RS Van Nuys built car on the gas tank.  The engine code is HD (block #172 on the broadcast sheet) and if I'm reading the carb application code correctly it is DD (block 176 on the broadcast sheet).  In 1969 HD is the engine code for the L65 with TH350 tranny.
The owner of this car and I have exchanged e-mails and I believe that he will be posting some detailed pics of the carb.  From pics that I have already seen, the carb currently on the car is indeed the Rochester 2Bbl, SAE 1-1/2" variant.
This has been previously discussed at:  http://www.camaros.org/forum/index.php?topic=3006.msg22733#msg22733.  This car provides additional documentation as to L65 carb. application.
This car also has RPO C60; air conditioning.  According to info. currently in the CRG Report, 350/250 engine with auto tranny and air conditioning used carb application code DF where this broadcast sheet indicates DD (if I'm reading it correctly).  In the report, DD is shown as correct for 350/250 with auto; without air.
« Last Edit: May 27, 2008, 10:18:31 PM by rich69rs »
Richard Thomas
1969 RS
opelitis1
Re: New CRG Report on 1st Gen Carburetors - L65 Engine
« Reply #1 on: May 27, 2008, 11:59:05 PM »
Good evening!!!  Suffix code HD was also good on '69 Chevelles as I have one namely 350ci
suffix coded TO 111 HD 19130@##@ with block 3956618 believe this carb came on the engine with 3932441 heads and the Cdn #3916313 iintake and carb 7029114  281 DD 81 if my eyes do me right...  Suffix code HD was also a Camaro code...  If you'd like I'll take a set of shots of this 114 carb demain matin (tomorrow morning)... I realize the pic(s) I sent were not of the best quality...  Let me know and I'll take more...   Ted
Damon
  • 69 Camaro RS
    • www.damonr.com
« Reply #2 on: May 28, 2008, 04:20:19 PM »
Hello,
Here are the numbers I located:
Tag on front top driver side# 37718
Front top # 2 JET ROCHESTER
Numbers on front pass. side of carb # 17058362
100  1  1
Enjoy
Damon
tom
    • Discount Internet Services
« Reply #3 on: May 28, 2008, 04:35:21 PM »
Damon, Go easy with the tools. That trim tag is soft metal, stick to a solvent cleaner of some sort.
69 X11 Z21 L14 glide
o
opelitis1
« Reply #4 on: May 28, 2008, 07:45:31 PM »
Hi Rich / Kurt!!!  I took some more pics of the 7029114 2bbl and will do the USB cable thing and load'em up either 2nite or demain soir (tomorrow night) Definately  281 DD as you will see... T.
motorman
« Reply #5 on: July 18, 2009, 03:15:04 PM »
Hello,
100  1  1
Enjoy
carb # 17058362 was used on 69 327/350 with MT/AT, AC/NON AC cars according to the Delco Rochester carb parts book
new Camaros owned 68 and 69 Z-28. new Corvettes owned 59,62,63,64,65,66,97,99 02,05 and 08. retired race engine builder, former NASCAR tech inspector
