Author Topic: speedometer cable  (Read 10500 times)
onebad34
speedometer cable
« on: May 19, 2008, 08:42:18 PM »
Does any know the correct length of a speedometer cable for a 1967 Camaro 396 4 speed?  Thanks in advance.
red67l78
Re: speedometer cable
« Reply #1 on: June 01, 2008, 02:05:34 AM »
Are there different lengths than a standard muncie 4 speed car?  350 vs 396.
« Reply #2 on: June 01, 2008, 02:39:28 PM »
Depends on the transmission - the Muncie cable went through the firewall ajdacent to the wiper motor to the passenger side of the transmission, and all others (3-speed, Saginaw 4-speed and automatics) went through the firewall below the fuse block to the driver's side of the transmission.
red67l78
« Reply #3 on: June 01, 2008, 09:21:53 PM »
So there is no difference from a small block or big block car?
« Reply #4 on: June 02, 2008, 02:24:21 PM »
Nope - the transmission, not the engine, determined the length of the speedo cable.
red67l78
« Reply #5 on: June 02, 2008, 02:57:15 PM »
Would you now the length of the cable ?
red67l78
« Reply #6 on: June 18, 2008, 10:39:24 AM »
Is this info not able to be found?  I forgot about this post and can't believe nobody answered it.
deejaygee
« Reply #7 on: June 18, 2008, 06:03:17 PM »
61"
