Author Topic: Good year Widetread GT tires  (Read 7494 times)
fireZ
« on: May 15, 2008, 01:28:04 AM »
What PSI do you guys run in your E-70-15 Widetread tires. They call for 34 PSI maximum. I am running with 28 PSI and they seem to run very hard on the road. thanks for your hep.
1968 Z28 LA Built
LIC # RPO Z28
hotrod68
  • almost finished
Re: Good year Widetread GT tires
« Reply #1 on: May 15, 2008, 04:04:05 AM »
We ran 32 psi in the original Goodyears in the '70s, Fire. I assume you have repros. Those things are going to ride hard at any psi compared to modern radials. The bias-plies just won't give and flex like a radial. But on the bright side, no radial has the handsome sidewall profile of a Wide Tread GT, nor the classic lettering and tread design. In their day, Goodyear Wide Tread GTs were THE tire to have! Wish I could lay my hands on a couple of L-60 14s now.....
fireZ
« Reply #2 on: May 15, 2008, 11:59:17 AM »
Thank you ,maybe I am expecting a better ride than I will ever get from the Wide Treads. thay do look good even if they ride terrible
1968 Z28 LA Built
LIC # RPO Z28
« Reply #3 on: May 15, 2008, 06:13:30 PM »
The recommended pressures are on the tire pressure sticker (and in the owner's manual); they're significantly lower than what you're accustomed to running in radials. I'm out of town right now, or I'd check mine.
« Reply #4 on: May 15, 2008, 06:44:50 PM »
Here's what my original '68 Z/28 tire pressure sticker reads...
Tire          Cool          Hot
Front          26           32
Rear           28           34
fireZ
« Reply #5 on: May 15, 2008, 07:24:32 PM »
I will try those psi.s and see if there is a differance.Hopfully they are a little smoother
1968 Z28 LA Built
LIC # RPO Z28
smallhurst
« Reply #6 on: November 12, 2010, 02:00:48 PM »
I agree.  A lot of people do not realize this fact.  I am bringing this to the top.  The polyglas on my '69 Hurst/ Olds are supposed to be at 26 #'s.  That tire would look down if it was a 70 series radial!!!
JoeC
« Reply #7 on: November 12, 2010, 02:35:36 PM »
you should check with the tire mfg
the repop tire is made of modern matarial which may require a different pressure
