Author Topic: Guidance on dating of components  (Read 8379 times)
Flowjoe
« on: May 08, 2008, 04:06:20 AM »
So it turns out I am missing two pieces that I thought I had, A 61 AMP Alternator and a distributor.  This is for an LA built '69 SS 350 AT w/AC with a trim tag date of 01D and an engine build date of T0117HB.
How far ahead of the car and the engine should these two components be?
Can I use the NCRS guideline of six months prior to build date for these?
KurtS, this would seem to be a good one for you. :)
Re: Guidance on dating of components
« Reply #1 on: May 08, 2008, 05:57:25 PM »
The distributor should be at least a week prior to the engine assembly date (it was installed at the engine plant), and the alternator should be at least a week prior to the car's final assembly date (it was installed on the engine dress line at the car assemby plant).
Flowjoe
« Reply #2 on: May 08, 2008, 09:22:04 PM »
that makes sense...how far back would you think its reasonable?  Same as for NCRS - up to  6 mos?
rich69rs
  • LF7/M35/Z22/Z87
« Reply #3 on: May 08, 2008, 11:52:54 PM »
Just another data point for you.  I have the original 37A alternator in my 69RS.  Car was assembled at Norwood around 20-21 Jan 1969.  Date code on the alternator is Jan 7, 1969.
Most alternators and distributors I've noticed seem to be within a month of engine assembly if not within 2 weeks.  Not sure how the judging rules apply - assume that they do allow for more of a range of acceptable dates.
Richard Thomas
1969 RS
Flowjoe
« Reply #4 on: May 09, 2008, 12:40:11 AM »
Thanks for the data point.  Based on some responses in another thread I went with an October 24th distributor...that would seem to fly.  I am still looking for an alternator
crobjones2
« Reply #5 on: May 09, 2008, 02:48:09 AM »
Another data point
My 06A 69 SS Norwood engine built late may (5-25) has an May 8th alternator
Chris
69 SS 350
