Author Topic: Over the counter Z28 intake  (Read 9261 times)
« on: May 02, 2008, 08:14:47 PM »
I have an intake that looks just like the 69 Z28 intake.  Instead of the casting # it has the part # 14044836 and a bowtie on the back edge of the carb flange.  Is this an over the counter intake?  I have had a How to Hot Rod a Chevy V8 book since the 70's.  In it, it has the Z28 intake listed as something to use and gives the above part # so I thought that's what this must be.
Re: Over the counter Z28 intake
« Reply #1 on: May 04, 2008, 03:22:32 PM »
If it doesn't have an oil fill tube hole and the screw holes for the remote choke thermostat aren't drilled and tapped, that's the over-the-counter GMPP PART number 10185024 intake, which is otherwise a duplicate of the original Z-28/LT-1 intake.
« Reply #2 on: May 04, 2008, 10:25:53 PM »
It has the oil fill tube hole, but it has a plug in it and the holes are tapped for the choke coil unit.
« Last Edit: May 04, 2008, 10:33:12 PM by 68Zproject »
« Reply #3 on: May 10, 2008, 04:07:44 AM »
Anyone know if this was over the counter or a replacement or what?  I seems to have a date of 11-69.
« Reply #4 on: May 10, 2008, 03:29:58 PM »
It's an over-the-counter GMPP replacement - production manifolds didn't have the bowtie.
« Reply #5 on: May 10, 2008, 04:01:32 PM »
Thank-you
