Author Topic: Research help needed, 68 front drum style, finned vs unfinned  (Read 107107 times)
CVKUEBER
Re: Research help needed, 68 front drum style, finned vs unfinned
« Reply #15 on: December 23, 2008, 10:46:01 PM »
68 230 CU IN. Manual drum. unfinned front and rear. O7C build.
kcracing
« Reply #16 on: January 17, 2009, 06:57:39 PM »
My car is a race car but from the doors to the front is all orig has finned brakes was ac car still has brake valve under car 11-b  los 11595  inter 719  pnt  d-d hope that helps.  Keith
Classic Gary
opinions are like wallets, some just aren't worth stealin'.
T-Bone
« Reply #18 on: February 13, 2009, 06:56:31 AM »
My '68 base 327 2bbl Powerglide, manual drum brake car has finned front drums, nonfinned rear drums.
It's a LOS car, built in June 1968.
sleepsinshed
    • Y2Camaro.com
« Reply #19 on: April 20, 2009, 08:26:42 PM »
1968 327/2bbl 4-spd. 12E build date, non power brakes. Non-finned drums front and back.
Oregonjam
  • 68 ss350
« Reply #20 on: May 15, 2009, 03:08:29 AM »
Might as well add the info for the future.
68 SS 350
Build Date: 07D (July, 1968 - 4th week)
Norwood, Ohio
Power brakes
Drums Front - Ribbed
Drums Back - Non-Ribbed
68 07D SS350
John
ChrisM
« Reply #21 on: January 14, 2010, 04:47:01 PM »
2E Nor RS/SS BBC - finned on front, no fins on rear.
10E Los base V8 - no fins.
rare396bronze
« Reply #22 on: January 15, 2010, 03:55:03 AM »
Have 68 327 2bbl front smooth original owner 06b car 68. Had 396 that had finned drum brakes 11d 68. Was under impression that ss car's had finned other's had smooth. Not positive but hope this helps. Also use to have a 67 & 68 327 2bl car's both had smooth front drum's.
« Reply #23 on: January 15, 2010, 02:14:04 PM »
qwertyme77 - what was the builddate of your car? By air, you mean AC, right?
T-Bone - AC on your car? What's the complete build date?
kcracing - do you know what engine originally was in your car?
Thanks guys!
tom
    • Discount Internet Services
« Reply #24 on: January 15, 2010, 10:44:41 PM »
Didn't realize you were interested in 69 data.
69 2D 307 powerglide not finned front or rear not power no a/c
69 X11 Z21 L14 glide
o
stovebolt
  • 1968 L6 Sport Coupe
« Reply #25 on: January 23, 2010, 10:52:41 PM »
1968 Norwood-built, 04A, 6 cylinder, manual brakes, no fins front or rear. I am the second owner and have owned the car since 1988 so I know the drums are the originals.
nwsgjr
« Reply #26 on: January 28, 2010, 07:48:27 AM »
68 12E finned front and rear owned since 1974 non power brakes no ac small block ...manual trans
« Reply #27 on: January 29, 2010, 05:19:25 AM »
Two cars finned in the rear, all others are unfinned.
All SS's have finned fronts so far. So I broke out the SS's to help see the other data.
Compiled by date, engine, front / rear drums, and comments: manual or power brakes or AC.
67:
02C LF7 unfinned / unfinned  manual
??   LF7 unfinned / unfinned  manual
68:
early LF7      finned / finned  manual
10E LF7    unfinned / unfinned
11B ??         finned / ??      AC
12E LF7    unfinned / unfinned manual
12E 327        finned / finned  manual
04A L6 NOR unfinned / unfinned  manual
04D L6 rag  unfinned / unfinned
06? LF7          finned / unfinned  manual
06B LF7      unfinned / unfinned
06D L30/M20  finned / unfinned
07C L6         unfinned / unfinned
07E L30/M35 unfinned / unfinned
??  LF7     finned / ??   J50 AC
??  LF7  unfinned / ??  Manual
11D SS396  finned / unfinned
02E SS396  finned / unfinned
04A SS396  finned / unfinned
06A SS350  finned / unfinned
07D SS350  finned / unfinned   J50
??    SS396  finned / ??   J50
69:
01C 307    finned / unfinned
02D 307 unfinned / unfinned
« Reply #28 on: March 01, 2010, 04:50:27 AM »
The car I referred to early on was an ss 350.  I don't have any of the data on it but I do have a bad picture of the cowl tag.  Did I send that to you before to try and read it?
« Reply #29 on: March 01, 2010, 10:51:21 PM »
I don't recall, but it sounds like I don't need it. :)
