Author Topic: Lower Control Arm Bolts Correct installation?  (Read 5572 times)
69z28302
« on: April 28, 2008, 05:32:37 PM »
I was installing the lower contorl arm on my 69 and wondered which way the nuts need to face towards the front on the car. I was looking at the AIM ( 3A1 & 3A2 ) for the 69 model and it shows the bolts being installed in opposite each other. Is this correct? I can't remember I took the car apart a year and a half ago. Any help would be appriciated.
Thanks CRG.
KevinW
Re: Lower Control Arm Bolts Correct installation?
« Reply #1 on: April 28, 2008, 07:12:30 PM »
I have seen them mostly nuts towards the front.  Probably easier to install from the factory.
jl8dale
« Reply #2 on: April 28, 2008, 07:19:05 PM »
In your picture, the nut nearest the motor mount bracket is in correctly, but the one up front is in backward.
1969 Z/28 Daytona Yellow/Yellow Houndstooth, Tilt, Fold Down Seat, - POP
Stillwater Camaro
« Reply #3 on: April 28, 2008, 07:24:02 PM »
On my 67, the bolts are inserted from the inside facing out, like JL8dale said. I see the nuts on the outside, front and back.
1967 Camaro SS/RS 350
1966 Chevelle SS 396
1970 Chevelle SS 396
69z28302
« Reply #4 on: April 28, 2008, 10:36:59 PM »
JL8 Dale & Stillwater Camaro, Thanks for the info. That's the way the 1969 Assembly Instruction Manual shows them also.
