Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Restoration
Lower Control Arm Bolts Correct installation?
« previous
next »
Print
Pages: [
1
Author
Topic: Lower Control Arm Bolts Correct installation? (Read 5575 times)
69z28302
Member
on:
April 28, 2008, 05:32:37 PM »
I was installing the lower contorl arm on my 69 and wondered which way the nuts need to face towards the front on the car. I was looking at the AIM ( 3A1 & 3A2 ) for the 69 model and it shows the bolts being installed in opposite each other. Is this correct? I can't remember I took the car apart a year and a half ago. Any help would be appriciated.
Thanks CRG.
Tweet
Logged
KevinW
Hero Member
Re: Lower Control Arm Bolts Correct installation?
Reply #1 on:
April 28, 2008, 07:12:30 PM »
I have seen them mostly nuts towards the front. Probably easier to install from the factory.
Logged
jl8dale
Member
Reply #2 on:
April 28, 2008, 07:19:05 PM »
In your picture, the nut nearest the motor mount bracket is in correctly, but the one up front is in backward.
Logged
1969 Z/28 Daytona Yellow/Yellow Houndstooth, Tilt, Fold Down Seat, - POP
Stillwater Camaro
Member
Reply #3 on:
April 28, 2008, 07:24:02 PM »
On my 67, the bolts are inserted from the inside facing out, like JL8dale said. I see the nuts on the outside, front and back.
Logged
1967 Camaro SS/RS 350
1966 Chevelle SS 396
1970 Chevelle SS 396
69z28302
Member
Reply #4 on:
April 28, 2008, 10:36:59 PM »
JL8 Dale & Stillwater Camaro, Thanks for the info. That's the way the 1969 Assembly Instruction Manual shows them also.
Logged
Print
Pages: [
1
« previous
next »
Restoration
