Author Topic: camaro two piece rotors  (Read 8077 times)
onebad34
« on: April 27, 2008, 12:59:11 AM »
I read the articles on the two piece rotors posted earlier. I was lucky enough to pick up two sets at spring carlisle this weekend.  Question, is there a difference between the 67's and the ones used on the 68-69 cars.  I was told that the 67's had holes drilled in the hat area to cool the bearings.  Are they interchangable and what do I need for on my 67 restoration project.  thanks Pete
red67l78
Re: camaro two piece rotors
« Reply #1 on: May 12, 2008, 12:50:06 AM »
I have the original ones on my car and picked up a set for spairs.  What holes are you talking about for cooling bearings?
I can't see putting holes were the bearings are for grease would come out.  I also don't think 69 rotors were the same for the single piston calipers.
rare4k
« Reply #2 on: May 12, 2008, 08:51:24 PM »
the outer edge of the hub has a cut back on it to clear the dual calipers,
RonM
« Reply #3 on: May 13, 2008, 12:32:08 AM »
I looked at the rotors on my "68" which I believe are original and only the drivers side has the holes, three of them. Also a few years ago I picked up complete hub assemblies off of another "68" for spare parts, again only the drivers side has the holes except only two. I don't know what the holes are for, possibly to balance the rotors. Hope this helps, RonM.
onebad34
« Reply #4 on: May 13, 2008, 10:40:56 PM »
thanks for the input. the two sets we picked up at carlisle, only two has the three holes in them. someone at carlisle said that was for cooling, I don't think so.  I would believe for balancing before I would believe cooling.  thanks.  Pete
L78 steve
« Reply #5 on: May 24, 2008, 01:06:07 AM »
The holes are for balance .The vents between the rotor faces are for cooling .Steve.
69 Z/28 Dover White. SOLD
« Reply #6 on: May 24, 2008, 05:34:51 AM »
