Author Topic: New guy saying hello!  (Read 5296 times)
Blown 67 RS
« on: April 25, 2008, 08:09:19 PM »
New guy saying hello-
Man lots of cool info here! I was looking for information on 67 Camaro shoulder belts and came across this site.
I realize most members here are about original restorations but wanted to share my Hot Rod 1967 RS with you guys. It is an original RS, 327, 4 speed car with a Deluxe Interior option. I am the third owner but haven’t done any VIN number tracking. I did not get the original drive train with the car when I bought it in 1989 and the drive train that came with the car was shot. The car was given a frame off restoration, with the bottom of the car painted the same as the exterior. Paint is Centari Single Step Guards Red with a Chrysler based grey metallic on all frame and suspension components. The car was restored in 1989 during the Pro Street Era when “tubs” were in, yet I refrained from cutting the car apart in hopes that it would retain its value over the years. I took a lot of crap from guys saying “tub it” but I’m glad I never chopped it up.
Today the car runs a heavily modified ‘73 LT-1 355 fed by a Dyers prepped 6-71 GMC blower forcing the AF mixture in at 10 psi of boost. The engine puts out somewhere @ 550 HP and will spin at 7,500 RPM all day. It is very reliable and can be driven in traffic all day with minimal issues. Power goes through a race modded T-400 using a 2500 stall and shifted with a Hurst 1/4 Stick. Power gets to the ground (barely) through a factory 12 bolt rear axle, built up with Moser axles and components housing GM 3.73 gears. The car has been lowered @ 3-4 inches and runs frame connectors and urethane body mounts and suspension bushings with adjustable drag shocks. I also added a front disc brake conversion to it using components from a 1970 GTO and a later model master cylinder and it made a world of difference in braking from the factory 4 wheel drum set up.
I used to go to a lot of car shows and spent many years (and brain cells) at the Car Craft Street Machine Nats. Now I just take it out on warm days and scare old ladies. It gets a lot of attention. I built the car myself and had it nearly 20 years. It still looks amazing since being painted 18 years ago. Hope you like my ride. ;)
More pictures HERE.
Scott
Western Suburbs of Chicago
ChevyThunder
    • Pro Racing
Re: New guy saying hello!
« Reply #1 on: April 27, 2008, 03:48:54 AM »
Welcome to the site ! I used to go to the Nationals in Sacramento and man was that a special time... sounds like it was similiar to deal:)
great looking car !
1969 X44 COPO
1969 X33 RS Z/28
hotrod68
  • almost finished
« Reply #2 on: April 27, 2008, 04:14:24 AM »
Nice ride! Welcome. My '68 is a hotrod, too, so I hear ya...chuckle. It has a naturally aspirated 406, Turbo 350/3500 stall, and Moser 4.11 12-bolt. Was originally a turquoise/black vinyl top plain Jane coupe with a 327, 4-speed and console and a 3.08 single-leg 10-bolt. I've had mine almost 25 years and am completing a frame-off resto/rod on it. It ran mid-12s with a mild 400 and 3.55s, and I'm hoping for solid 11s with the new engine. Nothing like a Saturday at the drag strip with the aromas of scalded rubber, combusted racing gas and the scream of a high-winding small-block! By the way--are those some old Cyclone 1-7/8" headers? Haven't seen a set of them in years!
