The cables for the astro ventilation (upper vents) in my 69 Z has broken plastic on the outside of the cable. Plastic is all there just split clean. Cable is fine just the hard plastic has dry rotted I guess. I was considering trying to fix the cables. Any ideas on how to glue or adher the hard plastic together so when you push the knob in on the kick panel the cable will push through the plastic.
