Author Topic: Doorlock problem  (Read 5427 times)
Danishbanker
    • www.bankmand.com
Doorlock problem
« on: April 19, 2008, 10:20:36 AM »
Hi
I have inclosed a pic - can you locate if there is a spring missing or something ?? Wops it didnt work so I have pasted a link.. canīt you post pics in here ??
The plates I have circled in is the one that can flip back and forward, and when the door is locked it just gets somehow in the way so den locksmecanismen wont open - if I flip it back again weith my finger it opens fine ?!?!?!
http://www.sitecenter.dk/bankmand/blandet/view.nhtml?profile=blandet&UID=10046
Hope to hear from one of you soon
Claus
* 55 Chevy Bel Air
* 67 Camaro RS
* Harley Fatboy
www.bankmand.com
crobjones2
Re: Doorlock problem
« Reply #1 on: April 19, 2008, 04:47:18 PM »
It appears to have a spring missing
I couldnt get a good pic of mine - I drew on your original pic approximately where the spring goes
Chris
69 SS 350
« Reply #2 on: April 19, 2008, 05:08:29 PM »
I don't remember exactly, but there should be a rod coming from the door lock knob at the top of the door to that lever with a hole in it about 2 inches below your red circle.  (The one you push down to lock the door from the inside.)  That rod is attached somehow to the door latch handle.  (The lever you pull to open the door from the inside.)  That lever has a spring built into it and keeps the lever in your red circle against the door knob push button.  It looks as if these rods are all missing or have fallen off to the bottom of the door.
Danishbanker
    • www.bankmand.com
« Reply #3 on: April 19, 2008, 08:50:12 PM »
Thanks for the pic Chris  :-*
That helps me a lot
/Claus
* 55 Chevy Bel Air
* 67 Camaro RS
* Harley Fatboy
www.bankmand.com
Danishbanker
    • www.bankmand.com
« Reply #4 on: April 20, 2008, 12:16:07 PM »
Just wanted to give an update...
Removed the door latch today, and manufactured a new spring with the right turn from a BSA mc front wheel.. Everything is installed again and work perfect ;-)
/Claus
* 55 Chevy Bel Air
* 67 Camaro RS
* Harley Fatboy
www.bankmand.com
