Author Topic: DZ 302 186 heads  (Read 39255 times)
Lukes 69 z28
DZ 302 186 heads
« on: April 07, 2008, 04:53:20 AM »
My 69 Z28 has the original engine dated I-8-9,010 block stamped VO908DZ .The original heads are missing. Does anyone have this same dated block and stamp so I could get the correct head dates? Build date of car is Norwood 09C  1969. thanks
Re: DZ 302 186 heads
« Reply #1 on: April 07, 2008, 08:15:29 PM »
A few weeks before the assembly date maybe a month being that it is an early car.
Dusk Blue Z
« Reply #2 on: April 07, 2008, 09:07:26 PM »
Wouldn't a I-8-9 block make it a late car? A couple of weeks or so before should be OK.
1969 Z/28 Legends Certified
1969 Z-10 350 4 speed
« Reply #3 on: April 07, 2008, 11:17:06 PM »
duh.... I knew that when I read it and got distracted at work... then wrote the response...
melav8r
« Reply #4 on: April 08, 2008, 02:02:30 AM »
I would say H 30 9's give or take a few days, typically 10-14 days before the engine assembly date is ideal, nothing set in stone on that one, just don't go any earlier than a month and not later than about 5 days prior to the engine assembly date. : )
« Reply #5 on: April 08, 2008, 02:54:50 PM »
Actually, it can be closer than five days between casting and machining/assembly; his block was cast on September 8th, and assembled the same day. Although it's not the "norm", we've documented a number of Corvette small-blocks from Flint that were cast and machined/assembled on the same day (cast early on the first shift at Saginaw, assembled late on the second shift at Flint). More "normative" separation, however, invites less scrutiny.
melav8r
« Reply #6 on: April 08, 2008, 09:01:38 PM »
John,
Are you saying you have documented heads cast the same day as the engine assembly?.
Lukes 69 z28
« Reply #7 on: April 09, 2008, 03:40:41 AM »
A while back a person told me he had the same build date and had H-29-9 heads .I just wanted a second opinion on another Z dated and  stamped the same as mine.
« Reply #8 on: April 15, 2008, 03:35:34 AM »
I don't recall if I've seen the same day, but the day before for sure. Intake (cast iron) can be the same way.
crobjones2
« Reply #9 on: April 15, 2008, 05:55:19 AM »
Quote
John
What was an average time from casting to assembly?
Did Chevrolet run the engine shop 7 days a week?
I ask because I thought my head - assembly time was short - cast on a thursday and assembled on a monday
Thanks for any insight you can provide
Chris
Chris
69 SS 350
« Reply #10 on: April 15, 2008, 02:03:37 PM »
Quote
John
Chris
Foundries never shut down - the melt cupolas ran continuously, although pouring of castings was normally a six-day operation on two 10-hour shifts; the Saginaw and Tonawanda foundries each produced about 55,000 castings per day for their respective engine plants. The Flint and Tonawanda engine plants ran the machining departments on three shifts, and assembly on two shifts, producing about 5500 engines per day each (one every 12 seconds).
Castings "typically" were machined within 2-10 days, although it could be much longer depending on inventory and demand for specific castings; production scheduling and inventory control in the 60's was nowhere near as precise as it is today.
Lukes 69 z28
« Reply #11 on: April 17, 2008, 02:42:16 AM »
Thanks for the help everyone,but I would still like to talk to someone who has a car that is dated close to mine.
« Reply #12 on: April 19, 2008, 04:41:15 AM »
Sometimes you gotta be happy you got a first opinion. :) That's kinda looking for a needle in a haystack.
They should be close.
melav8r
« Reply #13 on: May 16, 2008, 05:38:58 PM »
Is there a way to identify which foundry a block was cast, ie: Tonawanda vs Flint?
« Reply #14 on: May 16, 2008, 10:54:43 PM »
Definitely. The year portion of the casting date code on a Tonawanda block is two digits, and it's only one digit on a Saginaw casting (like C 3 9 on a Saginaw block, which would be C 3 69 on a Tonawanda block. Also, Saginaw/Flint blocks had a 1/8" NPT square-head plug in the front of the block, just above about 11 o'clock on the timing cover; Tonawanda blocks didn't have the hole or the plug. Photo below.
