Author Topic: Repro sheetmetal tip...  (Read 5034 times)
hotrod68
  • almost finished
« on: April 07, 2008, 03:58:58 AM »
   Here's a heads-up that may save someone some aggravation  I had to use new Goodmark doors on my '68 and when I tried to adjust the windows it was a nightmare. I spent literally hours trying to get the RS window to fit the weatherstrip and align with the roof rail, but no matter how I adjusted it, it would not raise up high enough in the back to fit right. Also, the front edge of the glass would hit the door.
   It turned out that the slots for the window cam had been punched a good one inch off the mark and had to be elongated, and I had to grind the door for clearance where the front of the window passes up out of the door. Hope this helps someone!
hihorse
Re: Repro sheetmetal tip...
« Reply #1 on: April 18, 2008, 09:06:45 PM »
sometimes good used doors would have been better
Stillwater Camaro
« Reply #2 on: April 28, 2008, 07:15:37 PM »
I cringe every time I read one of these reports.  You would think that after all this time, they could get it right. I have rust issues on my 67 too, but am going to save as much original as possible. That means hand fitting patch panels, but oh well. Thanks for the report........ ;)
1967 Camaro SS/RS 350
1966 Chevelle SS 396
1970 Chevelle SS 396
