Author Topic: Distributor  (Read 15569 times)
crobjones2
Distributor
« on: April 02, 2008, 03:04:40 AM »
Does anybody know what a 111125?( 1 or 7) came from? date is to corroded to decipher
Chris
69 SS 350
Re: Distributor
« Reply #1 on: April 02, 2008, 03:31:53 AM »
Chris,
1111251 is 1967 Pontiac 428  and 400
1111257 is 1968 Chevrolet, Chevelle, Nova, Chevrolet truck and GMC truck 307
crobjones2
Re: Distributor
« Reply #2 on: April 02, 2008, 05:34:15 AM »
From everything I know, that is the original distributor from my 06A 69 SS. Now I am confused as to why I have it.
Chris
Chris
69 SS 350
Re: Distributor
« Reply #3 on: April 02, 2008, 01:18:39 PM »
What is the date on the dist... should read a format like  9 B16  or something like that...  year (single number) month(alpha) day (2 numbers)
crobjones2
Re: Distributor
« Reply #4 on: April 02, 2008, 04:20:09 PM »
The number is not readable, there is too much corosion and pitting to make out any numbers or letters after the 5 - even the last digit of the part # is hard to make out
Chris
69 SS 350
Re: Distributor
« Reply #5 on: April 02, 2008, 04:43:09 PM »
Chris, a 1969 SS 350 should have a 1111488 (manual trans) or a 1111489 (automatic trans).
crobjones2
Re: Distributor
« Reply #6 on: April 02, 2008, 05:12:10 PM »
Those are the numbers I have been looking for- specifically the 489. I was confused as to why I have the other distributor. It was assumed to be the original when I switched to HEI back in the 90's. I have no paperwork that indicates any previous replacement. ( I have almost every reciept for repairs dating back to the mid 70's)
Chris
Chris
69 SS 350
Re: Distributor
« Reply #7 on: April 02, 2008, 06:10:39 PM »
I have a 489... will check the date if you are interested...
crobjones2
Re: Distributor
« Reply #8 on: April 02, 2008, 06:51:10 PM »
I am looking for an E date
Chris
Chris
69 SS 350
Jonesy
  • 1969 Camaro z28
Re: Distributor
« Reply #9 on: April 02, 2008, 06:51:46 PM »
488's seem to be harder to find. I suppose less manual trans cars.
1969 Z28 Azure Turquoise
Re: Distributor
« Reply #10 on: April 02, 2008, 10:47:14 PM »
sorry the date is for a very early car... 8H17
garysr2
Re: Distributor
« Reply #11 on: May 05, 2011, 08:03:00 PM »
        chris im looking for a 1111251 if u want to sell let me know 301 868 5515
Chris,
vtfb68
Re: Distributor
« Reply #12 on: May 09, 2011, 11:14:55 PM »
Distributors follow the motor build date, could be a gap between the motor build date and the car build date and you could end up with a distributor built before the the motor was built.
  VT
68 08E LA RS Y2 749 L30 M35
vtfb68
Re: Distributor
« Reply #13 on: May 10, 2011, 12:07:00 AM »
   Sorry Chris, I ment to type you could end up with a distributor built AFTER your motor was built.
  My motor was built in March, the trans in April, then the car in may.
     VT
tmodel66
Re: Distributor
« Reply #14 on: May 10, 2011, 01:03:25 AM »
     VT
Nope The distributor was installed at the engine assembly plant when the engine was built. The distributor must be dated before the engine build date.
