Author Topic: 5460346 Master Cylinder  (Read 46667 times)
Re: 5460346 Master Cylinder
« Reply #15 on: January 20, 2015, 03:12:05 PM »
Nope sorry.
« Reply #16 on: January 20, 2015, 04:08:00 PM »
The "D 1" is the pattern number at the Defiance (Ohio) GM foundry - that foundry logo is to the left of the "D".
bc69
« Reply #17 on: January 20, 2015, 04:40:10 PM »
John was there any connection to D 1,2,3,4 in time frames from Ohio? Just curious about the number. Most want to tie it to date codes in some way.
Brad
RSSS
« Reply #18 on: January 23, 2015, 05:25:38 PM »
Nope. It's not a date code - it's foundry pattern number identification.
bc69
« Reply #19 on: February 18, 2015, 03:00:56 AM »
Does this look correct?
Brad
RSSS
bc69
« Reply #20 on: February 18, 2015, 08:32:15 PM »
Opinions on this stamp. Original?
Brad
RSSS
« Reply #21 on: February 18, 2015, 10:26:59 PM »
Hi Brad,
    Normally the pad where the code is stamped has a more flatter machined look from some of the ones I have seen in the field. But that is not to say your example hasn't had some surface oxidation to cause the rough texture. I have two WT's on my '67's I can look at but from memory the fonts on yours look legit.
bc69
« Reply #22 on: February 18, 2015, 10:33:30 PM »
Thanks mike if you can post or pm me pic it would be great.
Brad
RSSS
HawkX66
« Reply #23 on: February 19, 2015, 12:48:14 PM »
Hi Brad,
I've seen a lot with the machined look also, but my original 309 US looks exactly like his surface. My stamping is barely legible though.
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
Stingr69
« Reply #24 on: February 19, 2015, 04:39:43 PM »
Pad looks aged as if it was rusted.  No expert here, but that stamp looks to be a little too fresh and crisp on an otherwise OLD looking surface . JMO
« Reply #25 on: February 19, 2015, 11:20:49 PM »
 Here are the two 'WT' master cylinders on my cars. Both are original to the car with the LOS unit being unrestored.
I looked all over and cannot find any Julian date besides the part number and foundry cast info.
The 05B NOR stamp has a light 'W' stamped compared to the LOS unit.
bc69
« Reply #26 on: February 19, 2015, 11:28:36 PM »
Mike I have seen both more than once. What's date on Los car.
I know of a early Los that has stamp like your nor .
Brad
RSSS
« Reply #27 on: February 19, 2015, 11:43:02 PM »
Hi Brad,
  The 04B LOS UOIT lists a date of April 13, 1967
For the 05B NOR car the NCRS document lists the date of May 12, 1967
Here is a close up of the NOR WT. The machining is not flat so the W isn't as crisp.
bc69
« Reply #28 on: February 19, 2015, 11:52:39 PM »
I was looking at stamps and looked over the one date code. Both cars are so close. But we all know there was a lot higher production numbers were higher in nor.
Well I'm still in the market for one for my 7. This all helps me with the hunt for orig.
There are a lot of faked ones out there.
Brad
RSSS
« Reply #29 on: February 20, 2015, 12:00:23 AM »
The NOR WT characters looks like the one you posted. Where is that from?
